Went to fix Minor Oil Leaks on Taco Plate, Not Expecting this |
914Sixer |
Jan 24 2015, 08:07 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I knew I had problems at the taco plate because it was really leaking there. Lots of grime and oil. I suspected a bad o ring, missing bolt crush washer or some one left the paper gasket off. Started to clean off the area when I found lots of RTV under the dirt. I started peeling back the layers and found 1/4 of the case ring was missing. (IMG:style_emoticons/default/WTF.gif) No damage anywhere to the rest of the case or the motor bar. I am lost as to how this got damaged. The only thing that comes to mind is a floor jack. I guess I will be looking for a new case and doing an overhaul. I just love DAPO's.
Attached image(s) |
mepstein |
Jan 24 2015, 08:26 PM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
maybe one of the knowledgeable engine builders will have another solution. You can't be the first to have this issue.
Lo-Fi Version | Time is now: 1st June 2024 - 07:05 AM |
