mechanical fuel pump location, Where's it go?? |
srthompson01 |
Jan 24 2015, 09:37 AM
Newbie Group: Members Posts: 45 Joined: 24-September 06 From: oklahoma Member No.: 6,906 |
I found a mechanical fuel pump for sale for carbeurated 914's on the automotion sight, but I've never seen one before on a 914, VW yeah.
http://www.automotion.com/porscher-fuel-pu...-1970-1974.html If it actually fits I think I'd like to try it, but, I don't wanna throw away $120 to find out it only works on a specific engine block produce only during the month of August for blue 914's with camel interiors. Can anyone fill me in? |
ClayPerrine |
Jan 24 2015, 09:59 AM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
All 914/4 engines used electric fuel pumps.
There is a un-machined boss on the left rear of the engine for a mechanical fuel pump that was used on the VW Type-IV. That is what the pump would fit. Unless you use a bus case, that pump won't work for you. |
stugray |
Jan 24 2015, 11:25 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
All 914/4 engines used electric fuel pumps. There is a un-machined boss on the left rear of the engine for a mechanical fuel pump that was used on the VW Type-IV. That is what the pump would fit. Unless you use a bus case, that pump won't work for you. And if you were to try it - What inside the case would actuate the pump? Usually there is a lobe on a cam that operates a mech pump. We dont have any such thing.... |
Mark Henry |
Jan 25 2015, 07:32 AM
All 914/4 engines used electric fuel pumps. There is a un-machined boss on the left rear of the engine for a mechanical fuel pump that was used on the VW Type-IV. That is what the pump would fit. Unless you use a bus case, that pump won't work for you. And if you were to try it - What inside the case would actuate the pump? Usually there is a lobe on a cam that operates a mech pump. We dont have any such thing.... You still have the lobe, pretty sure even the aftermarket cams have the lobe. |
Lo-Fi Version | Time is now: 7th June 2024 - 04:35 PM |
