Went to fix Minor Oil Leaks on Taco Plate, Not Expecting this |
914Sixer |
Jan 24 2015, 08:07 PM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I knew I had problems at the taco plate because it was really leaking there. Lots of grime and oil. I suspected a bad o ring, missing bolt crush washer or some one left the paper gasket off. Started to clean off the area when I found lots of RTV under the dirt. I started peeling back the layers and found 1/4 of the case ring was missing. (IMG:style_emoticons/default/WTF.gif) No damage anywhere to the rest of the case or the motor bar. I am lost as to how this got damaged. The only thing that comes to mind is a floor jack. I guess I will be looking for a new case and doing an overhaul. I just love DAPO's.
Attached image(s) |
thelogo |
Jan 25 2015, 12:05 AM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Ahem
But how did this happen :?? And If I don't have a taco plate then what do I have Xplain in depth please |
Mark Henry |
Jan 25 2015, 09:03 AM
Ahem But how did this happen :?? And If I don't have a taco plate then what do I have Xplain in depth please Why is not the question there is only fix. Fix it like above and then if you don't like the ghetto fix start collecting for a new long block. It was hit with force, hammer, rock, whatever, I don't see a jack doing that. |
Lo-Fi Version | Time is now: 7th June 2024 - 01:42 AM |
