mechanical fuel pump location, Where's it go?? |
srthompson01 |
Jan 24 2015, 09:37 AM
Newbie Group: Members Posts: 45 Joined: 24-September 06 From: oklahoma Member No.: 6,906 |
I found a mechanical fuel pump for sale for carbeurated 914's on the automotion sight, but I've never seen one before on a 914, VW yeah.
http://www.automotion.com/porscher-fuel-pu...-1970-1974.html If it actually fits I think I'd like to try it, but, I don't wanna throw away $120 to find out it only works on a specific engine block produce only during the month of August for blue 914's with camel interiors. Can anyone fill me in? |
ClayPerrine |
Jan 24 2015, 09:59 AM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
All 914/4 engines used electric fuel pumps.
There is a un-machined boss on the left rear of the engine for a mechanical fuel pump that was used on the VW Type-IV. That is what the pump would fit. Unless you use a bus case, that pump won't work for you. |
stugray |
Jan 24 2015, 11:25 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
All 914/4 engines used electric fuel pumps. There is a un-machined boss on the left rear of the engine for a mechanical fuel pump that was used on the VW Type-IV. That is what the pump would fit. Unless you use a bus case, that pump won't work for you. And if you were to try it - What inside the case would actuate the pump? Usually there is a lobe on a cam that operates a mech pump. We dont have any such thing.... |
Mark Henry |
Jan 25 2015, 07:32 AM
All 914/4 engines used electric fuel pumps. There is a un-machined boss on the left rear of the engine for a mechanical fuel pump that was used on the VW Type-IV. That is what the pump would fit. Unless you use a bus case, that pump won't work for you. And if you were to try it - What inside the case would actuate the pump? Usually there is a lobe on a cam that operates a mech pump. We dont have any such thing.... You still have the lobe, pretty sure even the aftermarket cams have the lobe. |
stugray |
Jan 25 2015, 05:23 PM
All 914/4 engines used electric fuel pumps. There is a un-machined boss on the left rear of the engine for a mechanical fuel pump that was used on the VW Type-IV. That is what the pump would fit. Unless you use a bus case, that pump won't work for you. And if you were to try it - What inside the case would actuate the pump? Usually there is a lobe on a cam that operates a mech pump. We dont have any such thing.... You still have the lobe, pretty sure even the aftermarket cams have the lobe. Ahh... that small bit on the end is offset from center so it would work? |
Lo-Fi Version | Time is now: 8th June 2024 - 03:13 AM |
