| Jeroen |
Aug 30 2004, 06:13 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Well, I got pretty much all of it out of the engine comp. and rear trunk
Took it out using a small wirebrush on an electric drill Only seamsealer left back there is around the heater tubes (where they come out of the longs) It's pretty impossible to get to with the wirebrush/drill in that location Same for the seamsealer in the front trunk (where the gas tank is) It's tight and hard to reach there Can I hit it with some nasty chemical? Will paint stripper work on this stuff? I'm not a fan of paintstripper, but I'm running out of options here... Any tips are welcome... cheers, Jeroen ps. so far, no rust found under any of the removed seam sealer... knock on wood for what's left... |
| jmargush |
Aug 30 2004, 06:27 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 501 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
You can use a propane torch if you are careful. It works really well if you have access to the backside of the metal that the sealer is on. Heat the metal from the back side then go tot he front side and use a puttty knife to scrape the sealer off. Two people, one with torch one with the putty knife, make it go a lot quicker
Jeroen Removing seam sealer... Aug 30 2004, 06:13 AM
dakotaewing I was doing the exact same thing this weekend.... ... Aug 30 2004, 06:35 AM
balljoint For tight spots I have used a flat head screw driv... Aug 30 2004, 08:40 AM
brant Jeroen,
Not answering your question...
but since... Aug 30 2004, 08:54 AM
Jeroen Thanks Brant
Hadn't looked in there yet (shoc... Aug 30 2004, 09:11 AM
SteveSr Jeroen,if you have the room an air chisel with a f... Aug 30 2004, 10:10 AM
zoomCat I saw something called a 'gasket scraper' ... Aug 30 2004, 12:23 PM
gopack Not to hijack this tread, but newbie that I am, I ... Aug 30 2004, 12:53 PM
brant Mark,
I've had cars where I did not remove ... Aug 30 2004, 01:15 PM
SteveSr <... Aug 30 2004, 01:36 PM
McMark Propane torch and a mask for the fumes and some sc... Aug 30 2004, 01:53 PM
9146986 We use a wood chisel, along with some wood gouges,... Aug 30 2004, 02:26 PM
mr914 I found that the paint stripper made by POR-15 wor... Aug 30 2004, 07:24 PM
McMark mr914, are you talking about the black rubberized ... Aug 30 2004, 08:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd April 2026 - 03:47 AM |
