| Jeroen |
Aug 30 2004, 06:13 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Well, I got pretty much all of it out of the engine comp. and rear trunk
Took it out using a small wirebrush on an electric drill Only seamsealer left back there is around the heater tubes (where they come out of the longs) It's pretty impossible to get to with the wirebrush/drill in that location Same for the seamsealer in the front trunk (where the gas tank is) It's tight and hard to reach there Can I hit it with some nasty chemical? Will paint stripper work on this stuff? I'm not a fan of paintstripper, but I'm running out of options here... Any tips are welcome... cheers, Jeroen ps. so far, no rust found under any of the removed seam sealer... knock on wood for what's left... |
| brant |
Aug 30 2004, 08:54 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Jeroen,
Not answering your question... but since I know how invested you are into the rear shock uprights.... There is a bunch of seam sealer upside of the uprights. I took a drill and round wire wheel (don't forget the safety glasses) and got 99.9% of the sealer out of these. After its out, you can then seam weld from the inside of the upright. There are a number of overlaping plates that are not accessible what so ever from the outside. I figured that this would have to help some, with strengthening the shock tops.... seeing as to how much effort you have already put into the same .... you may want to consider this while your there... $.02 brant |
Jeroen Removing seam sealer... Aug 30 2004, 06:13 AM
jmargush You can use a propane torch if you are careful. I... Aug 30 2004, 06:27 AM
dakotaewing I was doing the exact same thing this weekend.... ... Aug 30 2004, 06:35 AM
balljoint For tight spots I have used a flat head screw driv... Aug 30 2004, 08:40 AM
Jeroen Thanks Brant
Hadn't looked in there yet (shoc... Aug 30 2004, 09:11 AM
SteveSr Jeroen,if you have the room an air chisel with a f... Aug 30 2004, 10:10 AM
zoomCat I saw something called a 'gasket scraper' ... Aug 30 2004, 12:23 PM
gopack Not to hijack this tread, but newbie that I am, I ... Aug 30 2004, 12:53 PM
brant Mark,
I've had cars where I did not remove ... Aug 30 2004, 01:15 PM
SteveSr <... Aug 30 2004, 01:36 PM
McMark Propane torch and a mask for the fumes and some sc... Aug 30 2004, 01:53 PM
9146986 We use a wood chisel, along with some wood gouges,... Aug 30 2004, 02:26 PM
mr914 I found that the paint stripper made by POR-15 wor... Aug 30 2004, 07:24 PM
McMark mr914, are you talking about the black rubberized ... Aug 30 2004, 08:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd April 2026 - 03:48 AM |
