> A/C on a 3.2 Conversion, Building an A/C system
McMark
post Jan 5 2015, 09:13 PM
914 Freak!
We're doing an A/C install on a 3.2 project car and I though ya'll might like to see how it goes.
First I made a rough mockup of the location to test fit the setup in the car. This is just a TINY bit too high. I need to move it down and outwards a bit to clear things.
Once I had the general location I started making paper templates of the mount. It's a bit like putting together a puzzle, but instead of finding where pieces go, you just make your own as you go along. This will be made out of 1/8" plate most likely. The three circles you see will be bolts. The mount will be two pieces -- one underneath the tin and one on top. The tin will be sandwiched in between the two.
Oh man. How do I STILL not have a CNC plasma cutter. (IMG:style_emoticons/default/headbang.gif)
McMark
post Jan 29 2015, 01:32 PM
914 Freak!
Finally finished all these brackets. Figuring out how to handle the tensioning was the hardest part, but this works really well. The lower pivot of the compressor is a door-hinge style setup. Once that M10 bolt is tightened the tensioner will be doing very little work. I still have to trim the engine tin for belt clearance and the two holes for the mounting bolts.
All in all it's quite rigid and I've already test fit everything and it just clears. All in all this project took about 35 hours. (IMG:style_emoticons/default/w00t.gif) And this definitely needs to be tailored to each individual setup. So a bolt on kit is impossible. (IMG:style_emoticons/default/sad.gif)
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
McMark   A/C on a 3.2 Conversion   Jan 5 2015, 09:13 PM
JmuRiz   Very neat, a higher power engine like a 3.2 or 3.6...   Jan 5 2015, 09:18 PM
McMark   These are just typical 914-6 headers. This car ma...   Jan 5 2015, 09:19 PM
shoguneagle   The 3.2 heat exchangers can be modified and used. ...   Jan 5 2015, 09:56 PM
Mark Henry   What would be real cool, or should I say hot, is i...   Jan 5 2015, 09:58 PM
ConeDodger   No no no! I do not want to see how it goes...   Jan 5 2015, 10:28 PM
JStroud   No no no! I do not want to see how it goes...   Jan 5 2015, 11:08 PM
GeorgeRud   Does anyone have a picture of the factory 911 heat...   Jan 5 2015, 11:05 PM
JStroud   Mark, with that hanging over to the side so far wo...   Jan 5 2015, 11:11 PM
jeeperjohn56   Mark, when you get this figured out give me a call...   Jan 5 2015, 11:30 PM
McMark   Mark, with that hanging over to the side so far w...   Jan 6 2015, 02:08 PM
GeorgeRud   I wonder if there is enough clearance to allow a c...   Jan 6 2015, 03:11 PM
Cairo94507   Just what I do not want to see.....the one aspect ...   Jan 6 2015, 04:52 PM
Dave_Darling   Mark, I recall some concern about the mounting loc...   Jan 6 2015, 05:17 PM
McMark   Mark, I recall some concern about the mounting lo...   Jan 6 2015, 09:30 PM
Mueller   Nice mock-up Mark...if you need some billet parts ...   Jan 6 2015, 05:27 PM
76-914   If that's a rotary compressor it won't vib...   Jan 6 2015, 05:40 PM
crawler   If you guys ever get to Phoenix Arizona and need m...   Jan 6 2015, 05:59 PM
Mueller   If you guys ever get to Phoenix Arizona and need ...   Jan 6 2015, 06:18 PM
Travis Neff   :popcorn:   Jan 7 2015, 09:12 AM
jeeperjohn56   Mark, if you need a car to work with let know,you ...   Jan 8 2015, 01:31 AM
McMark   Got the steel version done. It's very rigid a...   Jan 9 2015, 12:49 PM
GeorgeRud   Great looking! I think you may have finally c...   Jan 9 2015, 03:10 PM
Steve   Wow!!! Looks great, but will it inter...   Jan 9 2015, 07:48 PM
McMark   I've realized there is too many combinations o...   Jan 9 2015, 09:19 PM
Steve   I've realized there is too many combinations ...   Jan 10 2015, 10:30 AM
Dave_Darling   I think he's saying that the bracket itself wi...   Jan 10 2015, 01:44 PM
larryM   interesting idea show me how this fits in a stock...   Jan 10 2015, 09:02 PM
McMark   It doesn't fit on a stock 914-6 engine mount. ...   Jan 11 2015, 10:47 AM
McMark   Finally finished all these brackets. Figuring out...   Jan 29 2015, 01:32 PM
Gary   Really slick! I'm guessing the "han...   Feb 1 2015, 06:49 AM
SirAndy   :trophy:   Jan 29 2015, 01:50 PM
ConeDodger   Saw it today in person! Installation looks fac...   Jan 29 2015, 07:38 PM
McMark   WHOA! Thanks to jcd914 (Jim) for pointing out...   Jan 31 2015, 12:17 AM
Steve   Too funny.. I was wondering why you had that dual...   Jan 31 2015, 10:53 AM
jeeperjohn56   Mark, are you going to make more mounts for 3.2 mo...   Feb 1 2015, 02:04 PM
mepstein   Wow! Nice job! Real heat exchangers become...   Feb 1 2015, 02:12 PM
okieflyr   That looks sweet! My question is do you thin...   Feb 1 2015, 06:27 PM
Cairo94507   I just hate that McMark has figured this out! ...   Feb 2 2015, 06:20 PM
bcheney   Great work. Why not at least offer a bolt on kit f...   Nov 17 2016, 05:44 AM
914dave   This is exciting! I'm going to assume that...   Nov 17 2016, 06:52 AM
gms   I would have never guessed you could fit that in w...   Nov 17 2016, 08:52 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:23 AM
