RustyWa |
Working Member ![]() ![]() ![]() Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 ![]() |
Just pulled off my heat exchangers and exhaust manifold "thingy-ma-jig" off the heads from my stock '75. There seems to be quite a bit of difference between the old nuts that attach the manifold to the heads and the new nuts I got from Pelican.
Are the existing ones I took off stock? They are much thicker and look much more "stout". Attached image(s) ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The ones on the left are the stock ones. They are really absurdly expensive--something like $10 each. The ones on the right are from an Audi (evidently a 924 as well) and work just fine. They are also much less $$, under a buck each I think.
Differences: The new ones are shorter. The new ones use a 12mm socket instead of 13mm; I have found the smaller socket is easier to get to the exhaust nuts when installed. The new ones are "squeezed" to lock; the old ones have a slice taken out of them to lock. They both have the "shoulder" that seats on the exhaust flange. They both are copper coated. They both work just fine. --DD |
Lo-Fi Version | Time is now: 3rd July 2025 - 04:03 PM |
