lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Wondering if anyone's tried to measure the engine bay temps, specifically down near the ECU, or over by the relay board.
I'm in the planning stages of a Megasquirt retrofit, and I'd like to mount the whole thing in the engine bay, rather than run a LOT of wires through the firewall. If the temperatures aren't too high (above 125dC, or about 250dF), then all I need is a waterproof enclosure and waterproof connectors in and out of that enclosure. Those are available (though they're expensive, and not part of the usual MS setup). If this works, I'll only have to run three new wires through the firewall for the serial programming connection (using the MegaView unit), rather than 14 to hook up to an MS mounted in the cabin. I'm pretty confident it's cool enough, as 125dC is bloody hot, but if anyone has any actual data, that would be useful. If it's normally below 80dC (180dF), then even cheaper lower-grade parts can be used. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
On a real hot day (about 90F) I've seen intake temps of a hair over 50C, this is on the gauge mode of my SDS system.
My SDS is mounted inside a gutted stock brain box...the engine connectors are waterproof but the ECU (and ECU connectors) are not. SDS reccomends mounting the coil packs at least 3 feet away (to prevent EMF) from the ECU. My coil packs are on the left side, but may be a bit under 3', with no issues. |
Lo-Fi Version | Time is now: 1st July 2025 - 04:17 AM |
