persistent window gap 1970, window doesn't seat into the rubber |
pgollender |
Feb 7 2015, 10:11 AM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
After installing my windows and re-conditioning the 1970 roll-up mechanism last year and adding some new 914 rubber all the way around, I have two persistent gaps where the window does not seat into the top rubber. The body is straight, does not sag and the door gaps and door height are all aligned and uniform so it is not the body. How do I adjust these gaps?
Mikey914 |
Feb 9 2015, 12:05 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The seal I make is slightly taller, it is like the superseded seal. The outer lip is designed to sweep over the outer scraper, and provide an additional barrier. This is one of the improvements the factory made to help keep water out.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 03:38 AM |
