| DRPHIL914 |
Dec 15 2014, 12:39 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
OK. car has been in shop for the past week, and today Bob spent several hours on it but what he found was when the MPS is disconnected from the vac hose it will idle and run, but when it gets connected it goes immediately lean and dies, and will not run with that hose on there- the MPS holds Vac no loss of pressure, but that doesnt mean that its not bad.
1- i thought that if an MPS went bad it defaulted rich? but when this is getting vac it goes lean right away and dies. but it will run and idle with out the vac , the AF meter then shows 9.8-10.2 or so which is of course rich but not flooding out. so the question is why is it going lean when hooked up? when this issue started about 2 weeks ago, it had been running just fine and all of a sudden it quit running. 2. could there be another issue we dont see that would be making it way to lean other than the MPS? might need to test another MPS, my 2nd one i just bought from someone here and it has never been opened but will not hold vac (slowly looses vac pressure) so it probably need to be opened and re-sealed. not a good candidate to trouble shoot with. ------ FYI- 1975 d-jet 2.0. newer wiring harness , CHT is newish(replaced 2 months before this issue started and was running perfect at that time) |
| DRPHIL914 |
Jan 26 2015, 01:40 PM
started this morning- so i drove it to work!(25 miles each way), as long as the rain stays away im going to driv it to work aleast 3x a week until it decides not to start or gives me fits. going to keep fiddling around until i figure out what the issue is.
so far since installing the tuna can and the nwe oil temp sensor and taco plate no leaks - but the VDO sender and the nitrous gauge seem to work fine together,- temp gauge reads almost exactly waht the dips stick thermometer reads. seems like this car still runs a bit hot. The air guides for under the car are not there. timing and advance are right on, not running lean. Does not go into dangerous levels but seems like at 50 degrees it would not go over 210 and after running for 30 minutes , under more load that temp will go up to the 230 - 235 range. (IMG:style_emoticons/default/confused24.gif) |
| DRPHIL914 |
Feb 11 2015, 07:57 AM
started this morning- so i drove it to work!(25 miles each way), as long as the rain stays away im going to driv it to work aleast 3x a week until it decides not to start or gives me fits. going to keep fiddling around until i figure out what the issue is. so far since installing the tuna can and the nwe oil temp sensor and taco plate no leaks - but the VDO sender and the nitrous gauge seem to work fine together,- temp gauge reads almost exactly waht the dips stick thermometer reads. seems like this car still runs a bit hot. The air guides for under the car are not there. timing and advance are right on, not running lean. Does not go into dangerous levels but seems like at 50 degrees it would not go over 210 and after running for 30 minutes , under more load that temp will go up to the 230 - 235 range. (IMG:style_emoticons/default/confused24.gif) over the last few weeks ive been driving the car a good bit. really running fine, but i either have to disconnect the battery or hook up the maintainer because if i go over a week with out running it it really gets run down so not sure whats up with that. - but back to the temp issue. ive bee rechecking this and it appears that the gauge reads about 230 or so when really warmed up , but the dipstick gauge actually reads closer to 180-190 which means that i probably need to get a VDO gauge to hook up that would read correctly from this VDO sender i installed, and 2. that it is cooling a bit better now with the deep sump installed as well. So now hopefully it will run good the next few weeks as there are several carsncoffee deals coming up in this area and as much fun as the TT has been to drive, its not the same as taking the 914.!!! |
Philip W. D_jet trouble shooting question - car is home, journey continues Dec 15 2014, 12:39 PM
SLITS D-Jet Trouble Shooting
On the MPS check the ohms... Dec 15 2014, 12:44 PM
Jeff Bowlsby There might be a couple things going on here. If ... Dec 15 2014, 01:22 PM
Philip W.
There might be a couple things going on here. If... Dec 15 2014, 03:16 PM
76-914 :WTF: That ain't right. :screwy: I've got ... Dec 15 2014, 05:06 PM
r_towle Flip the plug over on the MPS Dec 15 2014, 05:07 PM
Dave_Darling The MPS plug is bi-directional; flipping it should... Dec 15 2014, 05:59 PM
r_towle
The MPS plug is bi-directional; flipping it shoul... Dec 15 2014, 09:35 PM
worn
The MPS plug is bi-directional; flipping it shou... Dec 18 2014, 01:21 PM
Philip W. Dave, my fuel pressue is right at 30. I dont think... Dec 15 2014, 08:10 PM
SLITS A bad CHT can cause bad problems as in the car not... Dec 15 2014, 09:02 PM
Philip W.
A bad CHT can cause bad problems as in the car no... Dec 15 2014, 09:42 PM
914bub Not trying to Hi-jack here, but one of the hoses t... Dec 15 2014, 09:13 PM
BeatNavy
Not trying to Hi-jack here, but one of the hoses ... Dec 15 2014, 09:23 PM
Dave_Darling
Not trying to Hi-jack here, but one of the hoses ... Dec 16 2014, 10:48 AM
r_towle Get the car home.
you can do all the testing with ... Dec 15 2014, 10:55 PM
Philip W.
Get the car home.
you can do all the testing with... Dec 16 2014, 07:17 AM
I can send you down the official... Dec 16 2014, 09:18 AM
r_towle Oh, an interesting test.
Have your mechanic unplug... Dec 16 2014, 11:08 AM
Bleyseng
Have your mechanic unplu... Dec 16 2014, 08:13 PM
brant I've seen this once before. Ron's 74 LE d... Dec 16 2014, 10:00 PM
Philip W.
[url=http://members.rennlist.com/pbanders/DJetPar... Dec 17 2014, 01:00 PM
SLITS
i went over and tested the MPS at lunch time- hol... Dec 17 2014, 02:19 PM
Philip W.
i went over and tested the MPS at lunch time- ho... Dec 17 2014, 02:22 PM
Spoke
i went over and tested the MPS at lunch time- hol... Dec 17 2014, 04:00 PM
76-914
i went over and tested the MPS at lunch time- ho... Dec 18 2014, 09:33 AM
Philip W. going to re-test that CHT, and see wheere the valu... Dec 18 2014, 09:38 AM
SLITS If you have a digital multimeter and it read ... Dec 17 2014, 02:57 PM
Java2570 Phil, you've got a bizarre one going there... Dec 17 2014, 03:45 PM
Java2570 Did you ever try out that spare ECU I sent down? ... Dec 17 2014, 03:49 PM
Philip W. Usually a really lean condition will still run but... Dec 17 2014, 07:54 PM
r_towle Oh, you have already adjusted the MPS from the sto... Dec 17 2014, 08:41 PM
Philip W.
Oh, you have already adjusted the MPS from the st... Dec 18 2014, 09:29 AM
Philip W. alright a bit of an update: just spoke with Bob Wo... Dec 18 2014, 10:41 AM
Philip W. Picked up the car tonight and drove it home.
A/F m... Dec 18 2014, 11:21 PM
Racer Chris
A/F ... Dec 19 2014, 07:13 AM
Philip W.
A/F... Dec 19 2014, 02:22 PM
Dave_Darling So what did you do in order to drive the car home?... Dec 19 2014, 01:39 AM
Philip W.
So what did you do in order to drive the car home... Dec 19 2014, 05:32 AM
brant Was that mps a brand new one?
Sounds jet exactly l... Dec 19 2014, 08:40 AM
Philip W.
Sounds jet exactly ... Dec 19 2014, 02:25 PM
Jeff Bowlsby The only published MPS calibrations are on Brad An... Dec 19 2014, 03:05 PM
brant I agree
the factory setting are far from ideal
rem... Dec 19 2014, 03:51 PM
Philip W.
I agree
re... Dec 19 2014, 09:23 PM
76-914 FWIW Phil, that one is for a 75-76 so may run a bi... Dec 19 2014, 09:44 PM
76-914 Any news? Dec 21 2014, 09:26 AM
Philip W.
Any news?
Spent part of one day messing with it ... Dec 21 2014, 12:12 PM
Philip W.
Any news?
So I have not been able to try out the... Dec 27 2014, 10:57 PM
Jeff Bowlsby I wonder if this is related to the advance weights... Dec 27 2014, 11:13 PM
Philip W. No I've not done that. Dec 28 2014, 12:13 AM
Philip W. Is it possible for this one part, the temp sensor ... Dec 28 2014, 01:54 PM
Philip W. so yesterday i decided to try and figure out where... Dec 29 2014, 08:20 AM
Jeff Bowlsby Interesting. Never heard of a D-Jet 914 that did ... Dec 29 2014, 08:27 AM
r_towle its the ambient air temp, and I have never had one... Dec 29 2014, 08:29 AM
Philip W.
its the ambient air temp, and I have never had on... Dec 29 2014, 09:49 AM
r_towle if you still have an issue, I would go back to the... Dec 29 2014, 10:59 AM
Dave_Darling The intake air temp sensor doesn't contribute ... Dec 29 2014, 03:26 PM
Larmo63 After reading this thread and screwing around with... Dec 29 2014, 05:37 PM
BeatNavy
After reading this thread and screwing around wit... Dec 29 2014, 05:44 PM
r_towle
After reading this thread and screwing around wit... Dec 29 2014, 06:35 PM
Larmo63 Yes, engine is already built with Webers in mind. ... Dec 29 2014, 10:41 PM
Dave_Darling Should be fun! And if you already know Webers... Dec 29 2014, 10:49 PM
Philip W. Well back to the matter at hand..
Went to go drive... Jan 3 2015, 05:10 PM
Philip W. Put about 60 miles on it just 2 days ago. Was runn... Jan 3 2015, 05:19 PM
r_towle Injector grounds?
Distributor advance plate ground... Jan 3 2015, 06:43 PM
Philip W.
Injector grounds?
Distributor advance plate groun... Jan 3 2015, 10:36 PM
rhodyguy Remembered from long ago....I think Dave darling h... Jan 4 2015, 09:27 AM
Philip W.
Remembered from long ago....I think Dave darling ... Jan 4 2015, 05:58 PM
Dave_Darling Nope, not I.
--DD Jan 4 2015, 11:40 AM
Philip W. Last week end I went to try get workingrightthe ... Jan 24 2015, 12:53 PM
mepstein It's a snowbird car. Send it to FL for the win... Jan 24 2015, 02:04 PM
76-914 Is the plug on the backside of the dizzy clicked i... Jan 24 2015, 04:37 PM
Jeff Bowlsby Could it be an electrical connection? Harness iss... Jan 24 2015, 08:15 PM
Philip W.
Could it be an electrical connection? Harness is... Jan 24 2015, 08:56 PM
cary Did a quick read.
I'd disconnect the cold sta... Feb 11 2015, 08:23 AM
Philip W.
Did a quick read.
I'd disconnect the cold st... Feb 11 2015, 12:40 PM
Philip W. this goes back a few months and i never posted aft... Jun 24 2015, 01:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:23 AM |
