> Tips for removing rocker cheeseheads?
sdthomas
post Feb 13 2015, 02:26 PM
I'm trying to remove my rocker panels to inspect and clean out the longs but can't get the cheesehead screws loose. I've sprayed them with PB Blaster every day for a week, to no avail. Any other tips?
ThePaintedMan
post Feb 13 2015, 05:01 PM
Still think the impact screwdriver is worth a shot. Cheap and I guarantee you'll end up using it again. Much easier to get in there than vice grips and you won't risk burning the paint with flame. But all of the options mentioned have merit (IMG:style_emoticons/default/beerchug.gif)
sdthomas   Tips for removing rocker cheeseheads?   Feb 13 2015, 02:26 PM
bandjoey   Pb :shoot2kill: blaster for 36 hours heat vice gr...   Feb 13 2015, 02:30 PM
moldygreg   Pb :shoot2kill: blaster for 36 hours heat vice g...   Feb 13 2015, 02:35 PM
somd914   Pb :shoot2kill: blaster for 36 hours heat vice g...   Feb 13 2015, 02:38 PM
budk   Pb :shoot2kill: blaster for 36 hours heat vice ...   Feb 13 2015, 03:40 PM
ThePaintedMan   If those fail, this always works for me on stuck s...   Feb 13 2015, 03:20 PM
Johns914   If those fail, this always works for me on stuck ...   Feb 16 2015, 10:23 AM
The Cabinetmaker   Yes on the impact screwdriver. No to harbor freigh...   Feb 13 2015, 03:29 PM
pete000   I had one stubborn one and it eventually broke off...   Feb 13 2015, 03:40 PM
sdthomas   Thanks for all the advice! What's the bes...   Feb 13 2015, 03:50 PM
budk   Thanks for all the advice! What's the be...   Feb 13 2015, 03:59 PM
budk   delete - duplicate   Feb 13 2015, 03:59 PM
Steve Pratel   Thanks for all the advice! What's the be...   Feb 13 2015, 06:08 PM
Tom_T   Thanks for all the advice! What's the be...   Feb 13 2015, 06:09 PM
rgalla9146   That screw looks to be in very good condition. ...   Feb 13 2015, 04:18 PM
ThePaintedMan   Still think the impact screwdriver is worth a shot...   Feb 13 2015, 05:01 PM
Cuda911   I just ran into the exact issue last week. As ever...   Feb 13 2015, 05:14 PM
ThePaintedMan   Aha, good point Mike. I forgot that you'd have...   Feb 13 2015, 05:16 PM
rhodyguy   Soak in between the inner edge of the rocker. Tap,...   Feb 13 2015, 05:48 PM
pete000   I use Worth anti seize on everything ! Next ...   Feb 13 2015, 06:09 PM
warrenoliver   couple of years ago, I had the same problem. I go...   Feb 13 2015, 06:23 PM
pete000   couple of years ago, I had the same problem. I g...   Feb 13 2015, 10:22 PM
worn   couple of years ago, I had the same problem. I g...   Feb 14 2015, 09:34 AM
satche   couple of years ago, I had the same problem. I g...   Feb 14 2015, 12:49 PM
sdthomas   Got it! The combination of heat from a little...   Feb 14 2015, 04:58 PM
tdgray   Pb blaster is over priced oil water... Kroil is it...   Feb 13 2015, 06:42 PM
partwerks   I used one of those impact screw drivers, I think ...   Feb 13 2015, 09:21 PM
Vacca Rabite   Yep, Ive used impact screwdrivers on stuck screws ...   Feb 13 2015, 09:35 PM
euro911   Were cheese-heads the original type of fasteners u...   Feb 14 2015, 03:19 AM
rgalla9146   I've had cars high enough to use a hand impact...   Feb 14 2015, 07:28 AM
Krieger   I don't think anyone has said this, but get a ...   Feb 14 2015, 09:07 AM
tdgray   Throw some ospho on there while they are off.   Feb 16 2015, 06:50 PM
pete000   Love a good success story ! I had a similar f...   Feb 16 2015, 07:00 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:50 PM
