> Tips for removing rocker cheeseheads?
sdthomas
post Feb 13 2015, 02:26 PM
I'm trying to remove my rocker panels to inspect and clean out the longs but can't get the cheesehead screws loose. I've sprayed them with PB Blaster every day for a week, to no avail. Any other tips?
pete000
post Feb 13 2015, 03:40 PM
I had one stubborn one and it eventually broke off. Had to drill it out and re tap. Luckily it cleaned out OK.
Good Luck !
sdthomas
post Feb 13 2015, 03:50 PM
Thanks for all the advice! What's the best way to apply heat? Blow torch? Heat gun? I really don't want to strip them.
Bulldog9
post Feb 13 2015, 06:08 PM
QUOTE(sdthomas @ Feb 13 2015, 04:50 PM) *
I use a heavy duty soldering iron for screws in bodywork works great unless it is totally fused by rust. I don't see a big difference in wd40 or on pbblaster or liquid wrench
sdthomas   Tips for removing rocker cheeseheads?   Feb 13 2015, 02:26 PM
bandjoey   Pb :shoot2kill: blaster for 36 hours heat vice gr...   Feb 13 2015, 02:30 PM
moldygreg   Pb :shoot2kill: blaster for 36 hours heat vice g...   Feb 13 2015, 02:35 PM
somd914   Pb :shoot2kill: blaster for 36 hours heat vice g...   Feb 13 2015, 02:38 PM
budk   Pb :shoot2kill: blaster for 36 hours heat vice ...   Feb 13 2015, 03:40 PM
ThePaintedMan   If those fail, this always works for me on stuck s...   Feb 13 2015, 03:20 PM
Johns914   If those fail, this always works for me on stuck ...   Feb 16 2015, 10:23 AM
The Cabinetmaker   Yes on the impact screwdriver. No to harbor freigh...   Feb 13 2015, 03:29 PM
pete000   I had one stubborn one and it eventually broke off...   Feb 13 2015, 03:40 PM
sdthomas   Thanks for all the advice! What's the bes...   Feb 13 2015, 03:50 PM
budk   Thanks for all the advice! What's the be...   Feb 13 2015, 03:59 PM
budk   delete - duplicate   Feb 13 2015, 03:59 PM
Steve Pratel   Thanks for all the advice! What's the be...   Feb 13 2015, 06:08 PM
Tom_T   Thanks for all the advice! What's the be...   Feb 13 2015, 06:09 PM
rgalla9146   That screw looks to be in very good condition. ...   Feb 13 2015, 04:18 PM
ThePaintedMan   Still think the impact screwdriver is worth a shot...   Feb 13 2015, 05:01 PM
Cuda911   I just ran into the exact issue last week. As ever...   Feb 13 2015, 05:14 PM
ThePaintedMan   Aha, good point Mike. I forgot that you'd have...   Feb 13 2015, 05:16 PM
rhodyguy   Soak in between the inner edge of the rocker. Tap,...   Feb 13 2015, 05:48 PM
pete000   I use Worth anti seize on everything ! Next ...   Feb 13 2015, 06:09 PM
warrenoliver   couple of years ago, I had the same problem. I go...   Feb 13 2015, 06:23 PM
pete000   couple of years ago, I had the same problem. I g...   Feb 13 2015, 10:22 PM
worn   couple of years ago, I had the same problem. I g...   Feb 14 2015, 09:34 AM
satche   couple of years ago, I had the same problem. I g...   Feb 14 2015, 12:49 PM
sdthomas   Got it! The combination of heat from a little...   Feb 14 2015, 04:58 PM
tdgray   Pb blaster is over priced oil water... Kroil is it...   Feb 13 2015, 06:42 PM
partwerks   I used one of those impact screw drivers, I think ...   Feb 13 2015, 09:21 PM
Vacca Rabite   Yep, Ive used impact screwdrivers on stuck screws ...   Feb 13 2015, 09:35 PM
euro911   Were cheese-heads the original type of fasteners u...   Feb 14 2015, 03:19 AM
rgalla9146   I've had cars high enough to use a hand impact...   Feb 14 2015, 07:28 AM
Krieger   I don't think anyone has said this, but get a ...   Feb 14 2015, 09:07 AM
tdgray   Throw some ospho on there while they are off.   Feb 16 2015, 06:50 PM
pete000   Love a good success story ! I had a similar f...   Feb 16 2015, 07:00 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:50 PM
