> Air leaking into brake lines
jmargush
post Aug 31 2004, 06:19 AM
I am wondering if I might be drawing air into my brake system somewhere. I have bleed the system atleast 6 times and done all the tricks with the proportioning valve. I got a really good high, firm peadal the last time I bled them. A few days later it wasn't quite as good. then went and autoxed on Sunday and by the end of the day they were about gone unless I pumped them.
Question, if it is drawiing air in somewhere after the master cylinder wouldn't there be fluid leaking? If this is correct and I don't have fluid anywhere, the only thing left is where the lines go into the master cylinder which could draw air in without leaking fluid. Does this sound logical?
ArtechnikA
post Aug 31 2004, 06:45 AM
rich herzog
when your brakes cooled after the AX, did any of the pedal travel come back?
when you bleed with the 2-person or pressure-bleeder methods, do you actually get air bubbles in the fluid ?
what is your rear caliper venting clearance ?
jmargush   Air leaking into brake lines   Aug 31 2004, 06:19 AM
ArtechnikA   when your brakes cooled after the AX, did any of t...   Aug 31 2004, 06:45 AM
jmargush   Pedal didn't come back. the last time I bled ...   Aug 31 2004, 07:20 AM
ArtechnikA   ...   Aug 31 2004, 07:33 AM
jmargush   I bled them again and the pedal never got really f...   Aug 31 2004, 05:23 PM
SpecialK   ...   Aug 31 2004, 06:30 PM
ArtechnikA
- Lo-Fi Version Time is now: 2nd May 2026 - 03:41 AM
