> Installing new front trunk seal, Old one came out nice and clean
qa1142
post Aug 31 2004, 09:21 AM
Whiplash
What do I use to get the same nice seal and be able to remove the new seal when i have the car painted?
GaroldShaffer
post Aug 31 2004, 10:41 AM
You bought another 914?
Dont glue it in after you have the car done. You want to be able to pull it out each time you wash it, so you can dry the channel.
Is the concern here that the water will collect in the corners by the headlight buckets? When I get MY car painted I plan to cut a notch in the channel by the corner so the water will drain in behind the headlight and out the drain hole. Same for the bottom channel between the headlights, notch the corners so it will drain behind the bumper. Bad idea? (IMG:style_emoticons/default/confused24.gif)
- Lo-Fi Version Time is now: 1st May 2026 - 09:07 PM
