> Deck height, What went wrong?
DavidSweden
post Feb 18 2015, 03:31 PM
I am rebuilding my 2.0 engine
This evening I installed #4 cylinder & piston (with new rings). I then tightened the cylinder down onto the case to measure the deck height.
The deck height came to 0.2mm which is 0.008". as I understand it the deck height should be about 1mm (0.04").
I have installed new crank bearings, the piston and cylinder are original, the shim under the cylinder is the same thickness as the original shim.
The deck height should be the same as before the rebuild shouldn't it? Anyhow the deck height seem very small.
Advice appreciated
stugray
post Feb 18 2015, 06:57 PM
How are you holding the cylinder down?
I have a tool made by a member on this forum cant remember who...
Here is a pic:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1424307439.1.jpg)
You want to measure on both sides of the piston above the wrist pin.
Measure numerous times and rock the piston in the cyl.
If you are directly above the wrist pin, the meas wont change much as you rock it.
How are you measuring? with the "shim method"?
Or the "solder method"?
Or with a dial indicator like in my pic?
DavidSweden   Deck height   Feb 18 2015, 03:31 PM
76-914   David, sorry I haven't followed your build thr...   Feb 18 2015, 04:07 PM
DavidSweden   David, sorry I haven't followed your build th...   Feb 18 2015, 04:23 PM
tornik550   Are the rods also stock? Did you have the spigot...   Feb 18 2015, 04:19 PM
DavidSweden   Are the rods also stock? Did you have the spigo...   Feb 18 2015, 04:47 PM
SLITS   Spigots are the holes in the case where the cylind...   Feb 18 2015, 06:39 PM
stugray   How are you holding the cylinder down? I have a to...   Feb 18 2015, 06:57 PM
ThePaintedMan   Cylinders in the same order? As said before, was t...   Feb 18 2015, 08:14 PM
DavidSweden   Cylinders in the same order? As said before, was ...   Feb 19 2015, 04:40 AM
Mark Henry   Cylinders in the same order? As said before, was...   Feb 19 2015, 06:43 AM
tornik550   Cylinders in the same order? As said before, was...   Feb 19 2015, 06:45 AM
Racer Chris   The deck height minimum is to prevent the piston f...   Feb 19 2015, 08:22 AM
DavidSweden   The deck height minimum is to prevent the piston ...   Feb 19 2015, 09:35 AM
DavidSweden   The deck height minimum is to prevent the piston ...   Feb 19 2015, 03:43 PM
Racer Chris   Did you eliminate the oem head gaskets? That could...   Feb 19 2015, 09:59 AM
stugray   As Chris mentioned above, the deck height measur...   Feb 19 2015, 12:24 PM
Steve Pratel   I'm about 3 seconds less a rookie than you on ...   Feb 19 2015, 03:16 PM
Racer Chris   The head gasket crush is minimal. I recommend goin...   Feb 19 2015, 03:50 PM
Mark Henry   The head gasket crush is minimal. I recommend goi...   Feb 19 2015, 04:15 PM
Al Meredith   This happed to me once. One deck height was off on...   Feb 19 2015, 04:49 PM
Al Meredith   This happed to me once. One deck height was off on...   Feb 19 2015, 04:50 PM
Al Meredith   Do search and see if you can find a note from Jake...   Feb 19 2015, 04:56 PM
DavidSweden   Do search and see if you can find a note from Jak...   Feb 19 2015, 05:32 PM
Bleyseng   Don't use those stupid gasket rings between th...   Feb 19 2015, 06:47 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:27 PM
