| DavidSweden |
Feb 18 2015, 03:31 PM
Member ![]() ![]() Group: Members Posts: 481 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am rebuilding my 2.0 engine
This evening I installed #4 cylinder & piston (with new rings). I then tightened the cylinder down onto the case to measure the deck height. The deck height came to 0.2mm which is 0.008". as I understand it the deck height should be about 1mm (0.04"). I have installed new crank bearings, the piston and cylinder are original, the shim under the cylinder is the same thickness as the original shim. The deck height should be the same as before the rebuild shouldn't it? Anyhow the deck height seem very small. Advice appreciated |
| ChrisFoley |
Feb 19 2015, 09:59 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Did you eliminate the oem head gaskets?
That could account for part of the missing deck height. |
DavidSweden Deck height Feb 18 2015, 03:31 PM
76-914 David, sorry I haven't followed your build thr... Feb 18 2015, 04:07 PM
DavidSweden
David, sorry I haven't followed your build th... Feb 18 2015, 04:23 PM
tornik550 Are the rods also stock? Did you have the spigot... Feb 18 2015, 04:19 PM
DavidSweden
Are the rods also stock? Did you have the spigo... Feb 18 2015, 04:47 PM
SLITS Spigots are the holes in the case where the cylind... Feb 18 2015, 06:39 PM
stugray How are you holding the cylinder down?
I have a to... Feb 18 2015, 06:57 PM
ThePaintedMan Cylinders in the same order? As said before, was t... Feb 18 2015, 08:14 PM
DavidSweden
Cylinders in the same order? As said before, was ... Feb 19 2015, 04:40 AM
Mark Henry
Cylinders in the same order? As said before, was... Feb 19 2015, 06:43 AM
tornik550
Cylinders in the same order? As said before, was... Feb 19 2015, 06:45 AM
Racer Chris The deck height minimum is to prevent the piston f... Feb 19 2015, 08:22 AM
DavidSweden
The deck height minimum is to prevent the piston ... Feb 19 2015, 09:35 AM
DavidSweden
The deck height minimum is to prevent the piston ... Feb 19 2015, 03:43 PM
stugray
As Chris mentioned above, the deck height measur... Feb 19 2015, 12:24 PM
Steve Pratel I'm about 3 seconds less a rookie than you on ... Feb 19 2015, 03:16 PM
Racer Chris The head gasket crush is minimal.
I recommend goin... Feb 19 2015, 03:50 PM
Mark Henry
I recommend goi... Feb 19 2015, 04:15 PM
Al Meredith This happed to me once. One deck height was off on... Feb 19 2015, 04:49 PM
Al Meredith This happed to me once. One deck height was off on... Feb 19 2015, 04:50 PM
Al Meredith Do search and see if you can find a note from Jake... Feb 19 2015, 04:56 PM
DavidSweden
Do search and see if you can find a note from Jak... Feb 19 2015, 05:32 PM
Bleyseng Don't use those stupid gasket rings between th... Feb 19 2015, 06:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:25 PM |
