> Source of insulator tubing, The stuff that goes on the metal tabs
worn
post Feb 19 2015, 06:31 PM
I think I may have saved at least most of them but in a full body restore, I would prefer new. I am talking about the pieces of thin black flat tubing that goes on the metal tabs that hold the wiring harness and other delicate things to the body. The metal tabs are about a centimeter wide and curl over the wiring as it transits the body. They didn't want a short circuit so they installed this plastic tubing on the straps to stop chafing. I suppose it is made in rolls. Is there either a vendor or part number?
I hope you can help, as so often has been the case. Thanks (IMG:style_emoticons/default/pray.gif)
Larry.Hubby
post Feb 19 2015, 10:02 PM
Member who doesn't post much, but has a long time in 914s
You can order PVC sleeving that is very similar to the factory material from McMaster-Carr:
http://www.mcmaster.com/#catalog/121/849/=vzhcsn
Middle of the page on the right-hand side.
worn
post Feb 20 2015, 10:32 AM
QUOTE(Larry Hubby @ Feb 19 2015, 08:02 PM) *
Thanks. I know the shrink wrap would be good, but it is considerably thinner than stock. Normally I can use the creamy vinyl cleaner/preservative from Meguires to bring plastic back to life, but these only cleaned up, they are still rock solid rather than pliable.
- Lo-Fi Version Time is now: 2nd April 2026 - 04:34 PM
