2.7 Six conversion questions, Oil cooler and motronic |
bigkensteele |
Feb 26 2015, 10:19 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Topic 1: Has anyone ever tried mounting an oil cooler under a GT lid just above the fan, and if so does it keep the temp low enough for DE events?
Topic 2: Has anyone here ever adapted motronic from a 3.2 to work on a 2.7? If so, what is involved? Which distributor? What cam? Stock low compression CIS pistons or JEs? Topic 3: What kind of power can I get if I keep the CIS but am willing to port the heads, change cams and go to JE pistons? Please feel free to address any or all of the above? I have a '74 2.7 core that is currently torn apart and ready to send out for machining. It already has case-savers and nikasil jugs, so I am going to stay at 2.7. I have all of the CIS parts, so that is an option for induction, but I would rather do something else (other than carbs). I will also be running stock 6 heat exchangers and a 911 muffler. I just can't bear the thought of rebuilding this thing and only ending up with 150 hp, so any tips would be most appreciated. |
GeorgeRud |
Feb 26 2015, 10:26 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
My 2.7 has RS pistons, S cams, and Webers with an Electromotive ignition. It put out 199 hp at the wheels, so you can get power. I'd investigate getting the Bitz EFI system if you have the CIS parts. You can't do much more cam retaining the CIS.
Lo-Fi Version | Time is now: 1st June 2024 - 04:09 AM |
