| mepstein |
Feb 28 2015, 10:40 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
In the past I:
Ran new fuel and vacume lines Cleaned the interior Replaced seals and gaskets on the fuel injection Today I decided it was time to replace the charcoal in the canister next to the fuel tank I purchased some replacement charcoal on Amazon. I've read that this isn't optimal but I feel it's got to be better than leaving the 45 year old origional mixture in the car. Attached thumbnail(s) |
| r_towle |
Feb 28 2015, 02:37 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
It takes away the smell in the trunk which flows into the cabin.
Alternately, you can run a hose from the expansion tank down along side the drain tube and have it exit under the car like was done for 60 years up until the 70,s California inspection may be looking for a functional setup, so you would need to re route the intake hose into one of the carbs. I put mine out under the car, it's fine. You need to let the pressure out of the tank as it heats and cools. The canister setup does that in an environmentally friendly way by sucking the fumes through the charcoal and also burning it via the intake. If you just let it air into the front trunk your car will always smell like fuel. |
mepstein Getting rid of the gas smell Feb 28 2015, 10:40 AM
mepstein Unlike the mid and late model 914's, on the ea... Feb 28 2015, 10:43 AM
mepstein Originally I drilled a small hole but when I dumpe... Feb 28 2015, 11:01 AM
porsche913b_sp Keep us updated if it gets rid of the gas smell. I... Feb 28 2015, 11:27 AM
mepstein The new lines, clamps and seals made a big differe... Feb 28 2015, 11:35 AM
mepstein Next time I'll use a hole saw with the same di... Feb 28 2015, 12:42 PM
Larmo63 Maybe, (probably) a dumb question here, but do tho... Feb 28 2015, 01:36 PM
quadracerx
It takes away the smell in the trunk which flows ... Sep 27 2015, 01:00 PM
patssle What about gas/moisture getting into the canister ... Feb 28 2015, 03:56 PM
bperry I'll be curious how well it works. The main th... Sep 27 2015, 02:05 PM
boxsterfan Did you change the rubber gasket on the fuel fille... Sep 27 2015, 05:10 PM
Dominic
Did you change the rubber gasket on the fuel fill... Sep 28 2015, 10:26 PM
Vysoc Question for bperry?
Is there enough room in the ... Sep 27 2015, 05:53 PM
bperry
Is there enough room in the... Sep 28 2015, 10:21 PM
mepstein Guys, make sure you have replaced all 3 seals on t... Sep 27 2015, 05:56 PM
arsprod
Guys, make sure you have replaced all 3 seals on ... Oct 9 2015, 09:16 PM
Guys, make sure you have replaced all 3 seals on... Oct 10 2015, 06:10 AM
RobW
[quote name='arsprod' post='2249994' date='Oct 9 ... Oct 10 2015, 06:18 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:12 PM |
