Battery boiling over?, What causes |
georgia914 |
Sep 1 2004, 10:49 AM
Newbie Group: Members Posts: 14 Joined: 28-July 04 From: Hogansville, Ga. Member No.: 2,413 |
Alright guys...
My voltage is reading steady 16 on the guage while car is running. The battery is boiling over every time I crank. also if you are on the gas and let off, the rpms drop till the engine almost dies then comes back to 900 immediately? Vaccuum advance doing that? (IMG:style_emoticons/default/bootyshake.gif) |
bondo |
Sep 1 2004, 10:56 AM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Something is seriously wrong with yor charging system. Probably your voltage regulator. Fix that, and your idle problem may go away too. Your battery should never see over about 14.5 volts. You will probably need a new battery... Get a sealed unit like an optima, so you don't rust your car to pieces. Also, spread plenty of baking soda all over under the battery, and sprinkle with water... keep doing that until the fizzing stops, then rinse well.
Lo-Fi Version | Time is now: 10th June 2024 - 03:04 PM |
