> Front Rotor/Bearing Replacement
seanery
post Sep 1 2004, 10:29 AM
waiting to rebuild whitey!
Quick questions...how much grease? What kind? What do I torqe bearing retainer to?
thanks!
getting a bit dirty! woohoo! (am I motivated? I'm trying (IMG:style_emoticons/default/smile.gif) )
lapuwali
post Sep 1 2004, 03:24 PM
Not another one!
I don't agree with seating the races "on the fly". Races should be seated firmly "before" you begin the bolt it back together phase.
I agree.
If you have to keep tightening and tightening to seat races and you're using your bearings to do this I'd think things aren't going well...
I don't quite agree. First, not everyone has access to a press. However, any sufficiently strong screw (like the spindle and the retaining nut) works very well as a nice, gentle press. Seating them as well as you can with hand tools, enough to get the seals installed, then finishing the last bit with the retaining nut, seems to be a perfectly sensible procedure. I hardly invented the idea. It's taken right out of the shop manual for most Alfa Romeos, which have a nearly identical front hub design as the 914. Indeed, the Alfa manuals even specify a torque value for the "seating" phase, then another torque value for the second phase (33 v 7 ft/lbs, if I remember correctly). Repeating the process later also ensures that after everything's gone through a few heat cycles ensures things are fully seated, and there's no need to remove everything, just take off the dust cap and go through the two tightening cycles again.
It may not be necessary, but I don't see where it hurts, and I can see where it *could* help.
And seanery, yes, you should have frozen at least the races first. I've never had to heat the hub (no really access to something to do this properly w/o endangering my marriage), but freezing the races helps a lot.
I don't grease the hub, and certainly don't want any between the race and the hub. This is supposed to be an interference fit, so there's shouldn't be any clearance for even a small amount of grease in between the race and the hub. The very last thing you want is to invite even the possibility of the race spinning wrt to the hub. The spindle should never touch the hub itself, and should rest entirely on the bearings, which also should not spin wrt the spindle, so you don't want that greased, either. Perhaps I'm misunderstanding what's being said here...
seanery   Front Rotor/Bearing Replacement   Sep 1 2004, 10:29 AM
seanery   no good advice? I'm surprised! Don't ...   Sep 1 2004, 11:06 AM
jim912928   Sean...just did this about 4 weeks ago. I'm a...   Sep 1 2004, 11:08 AM
lapuwali   I use wheel bearing grease (happen to use Castrol)...   Sep 1 2004, 11:28 AM
SpecialK   Yep, what James said. I did mine about 3 weeks ag...   Sep 1 2004, 12:26 PM
seanery   so the only grease in the whole ensemble should be...   Sep 1 2004, 12:59 PM
seanery   Well, I think i have a problem. I've got the ...   Sep 1 2004, 02:08 PM
lapuwali   There's a seat for the races in the hub, and t...   Sep 1 2004, 02:21 PM
Eric_Shea   Doesn't sound like the race is seated properly...   Sep 1 2004, 02:23 PM
seanery   when the race is in is there 1 cm clearance betwee...   Sep 1 2004, 02:26 PM
tbil   Yep, need to tap the race further into the hub. A...   Sep 1 2004, 02:28 PM
seanery   hell, I knew I shoulda put the fronts in the freez...   Sep 1 2004, 02:28 PM
Eric_Shea   One other thingy... it could be me but; I don...   Sep 1 2004, 02:30 PM
Eric_Shea
  Sep 1 2004, 02:32 PM
lapuwali
SpecialK   No grease on the the races, and clean the mating h...   Sep 1 2004, 04:30 PM
seanery   well damn. what a pain. races are freezing, so I ...   Sep 1 2004, 04:40 PM
Eric_Shea
  Sep 1 2004, 04:45 PM
seanery   Yeah, that confused me too. Mr. Haynes can be vagu...   Sep 1 2004, 04:47 PM
Engman   Which 914 of yours are you redoing? Yep I got som...   Sep 1 2004, 04:54 PM
lapuwali   Eric, I agree that it's good practice IF YOU H...   Sep 1 2004, 05:05 PM
seanery   Mr. Haynes agreed with Eric. But I agree with the ...   Sep 1 2004, 05:20 PM
- Lo-Fi Version Time is now: 4th July 2025 - 11:30 PM
