| BeatNavy |
Mar 7 2015, 06:11 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Ok, this should be easy. I have the engine sitting on a dolly, and I'm trying to figure out where I access the oil cooler seals so I can replace them while the engine's out. I know they are on the vertical side of the cooler, and probably on the inside (not outside) side of the cooler, right? Getting access under the engine is a little difficult since it's on the dolly and I currently don't have a good view up directly underneath. What do I need to remove in order to get access to those seals? Should I attack it from the top or from underneath? I started to remove the oil filter housing but the top nut is pretty well hidden too...
| mepstein |
Mar 7 2015, 06:59 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
One or 2 pieces of engine tin and the right size wrench does it. I did it so you know its not too hard. Take your time and you'll be good. Cooler isn't completely removed, just pulled out a bit to replace the seals. I don't know how the guys do it with the engine in the car.
BeatNavy Replacing Oil Cooler Seals Mar 7 2015, 06:11 PM
BeatNavy
One or 2 pieces of engine tin and the right size ... Mar 7 2015, 07:04 PM
Dave_Darling Just remove the fan and fan shroud. Three bolts (... Mar 7 2015, 07:40 PM
BeatNavy Sweet, thanks Dave. That must be the "trick.... Mar 7 2015, 07:47 PM
Larmo63 The front of the motor is like a big puzzle. It lo... Mar 8 2015, 12:09 AM
bandjoey http://www.pelicanparts.com/techarticles/9...ooler... Mar 8 2015, 10:53 AM
r_towle Yup, remove fan, fan housing, alternator.
Oil cool... Mar 8 2015, 01:44 PM
BeatNavy Cool, thanks for the comments, gentlemen.
Yup, t... Mar 8 2015, 04:06 PM
r_towle Grease gun hose or paint ball gun hose
Rich Mar 8 2015, 04:16 PM
BeatNavy
Rich
Ok,... Mar 8 2015, 04:26 PM
BeatNavy Here's the engine tin after powdercoating. No... Mar 8 2015, 04:28 PM
The Cabinetmaker Your missing two little flat pieces of metal that ... Mar 8 2015, 05:09 PM
BeatNavy
Your missing two little flat pieces of metal that... Mar 8 2015, 05:14 PM
BeatNavy Never mind. I see it on my other car. Thanks Cur... Mar 8 2015, 05:49 PM
Stltri Reviving an old thread.
Can someone confirm the ... Feb 14 2022, 07:35 PM
BeatNavy Dayummm... this is an old thread. I had forgotten... Feb 14 2022, 07:47 PM
Stltri
Dayummm... this is an old thread. I had forgotte... Feb 14 2022, 08:06 PM
914Mels It looks like the remote hose has straight threads... Feb 14 2022, 11:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:59 AM |
