> Replacing Oil Cooler Seals, Engine out, this should be easy, right?
BeatNavy
post Mar 7 2015, 06:11 PM
Ok, this should be easy. I have the engine sitting on a dolly, and I'm trying to figure out where I access the oil cooler seals so I can replace them while the engine's out. I know they are on the vertical side of the cooler, and probably on the inside (not outside) side of the cooler, right? Getting access under the engine is a little difficult since it's on the dolly and I currently don't have a good view up directly underneath. What do I need to remove in order to get access to those seals? Should I attack it from the top or from underneath? I started to remove the oil filter housing but the top nut is pretty well hidden too...
Dave_Darling
post Mar 7 2015, 07:40 PM
914 Idiot
Just remove the fan and fan shroud. Three bolts (may be "triple squares") hold the fan on, once those are off there are four nuts that hold the fan shroud onto the case. Pull the shroud forward and off (don't forget to unhook the alternator cooling boot!!) and the cooler will be right there. Remove the retaining nuts, pull the cooler off, replace the seals, then put everything back together.
It's a lot easier than lying on your back trying to fish the seals up into place.
--DD
BeatNavy   Replacing Oil Cooler Seals   Mar 7 2015, 06:11 PM
mepstein   One or 2 pieces of engine tin and the right size w...   Mar 7 2015, 06:59 PM
BeatNavy   One or 2 pieces of engine tin and the right size ...   Mar 7 2015, 07:04 PM
Dave_Darling   Just remove the fan and fan shroud. Three bolts (...   Mar 7 2015, 07:40 PM
BeatNavy   Sweet, thanks Dave. That must be the "trick....   Mar 7 2015, 07:47 PM
Larmo63   The front of the motor is like a big puzzle. It lo...   Mar 8 2015, 12:09 AM
bandjoey   http://www.pelicanparts.com/techarticles/9...ooler...   Mar 8 2015, 10:53 AM
r_towle   Yup, remove fan, fan housing, alternator. Oil cool...   Mar 8 2015, 01:44 PM
BeatNavy   Cool, thanks for the comments, gentlemen. Yup, t...   Mar 8 2015, 04:06 PM
r_towle   Grease gun hose or paint ball gun hose Rich   Mar 8 2015, 04:16 PM
BeatNavy   Grease gun hose or paint ball gun hose Rich Ok,...   Mar 8 2015, 04:26 PM
BeatNavy   Here's the engine tin after powdercoating. No...   Mar 8 2015, 04:28 PM
The Cabinetmaker   Your missing two little flat pieces of metal that ...   Mar 8 2015, 05:09 PM
BeatNavy   Your missing two little flat pieces of metal that...   Mar 8 2015, 05:14 PM
BeatNavy   Never mind. I see it on my other car. Thanks Cur...   Mar 8 2015, 05:49 PM
Stltri   Reviving an old thread. Can someone confirm the ...   Feb 14 2022, 07:35 PM
BeatNavy   Dayummm... this is an old thread. I had forgotten...   Feb 14 2022, 07:47 PM
Stltri   Dayummm... this is an old thread. I had forgotte...   Feb 14 2022, 08:06 PM
914Mels   It looks like the remote hose has straight threads...   Feb 14 2022, 11:28 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:59 AM
