> Front Rotor/Bearing Replacement
seanery
post Sep 1 2004, 10:29 AM
waiting to rebuild whitey!
Quick questions...how much grease? What kind? What do I torqe bearing retainer to?
thanks!
getting a bit dirty! woohoo! (am I motivated? I'm trying (IMG:style_emoticons/default/smile.gif) )
Engman
post Sep 1 2004, 04:54 PM
Zoisite
Which 914 of yours are you redoing?
Yep I got some of those brake lines once - I believe they are for the 911.
How are you pad retainers......... mine were junk. It was even more fun when I found the DAPO had sussefully cross threaded the fles line to the hard line. Had to replace the hard line.
Good luck with the brakes - what is next?
M
seanery   Front Rotor/Bearing Replacement   Sep 1 2004, 10:29 AM
seanery   no good advice? I'm surprised! Don't ...   Sep 1 2004, 11:06 AM
jim912928   Sean...just did this about 4 weeks ago. I'm a...   Sep 1 2004, 11:08 AM
lapuwali   I use wheel bearing grease (happen to use Castrol)...   Sep 1 2004, 11:28 AM
SpecialK   Yep, what James said. I did mine about 3 weeks ag...   Sep 1 2004, 12:26 PM
seanery   so the only grease in the whole ensemble should be...   Sep 1 2004, 12:59 PM
seanery   Well, I think i have a problem. I've got the ...   Sep 1 2004, 02:08 PM
lapuwali   There's a seat for the races in the hub, and t...   Sep 1 2004, 02:21 PM
Eric_Shea   Doesn't sound like the race is seated properly...   Sep 1 2004, 02:23 PM
seanery   when the race is in is there 1 cm clearance betwee...   Sep 1 2004, 02:26 PM
tbil   Yep, need to tap the race further into the hub. A...   Sep 1 2004, 02:28 PM
seanery   hell, I knew I shoulda put the fronts in the freez...   Sep 1 2004, 02:28 PM
Eric_Shea   One other thingy... it could be me but; I don...   Sep 1 2004, 02:30 PM
Eric_Shea
  Sep 1 2004, 02:32 PM
lapuwali
  Sep 1 2004, 03:24 PM
SpecialK   No grease on the the races, and clean the mating h...   Sep 1 2004, 04:30 PM
seanery   well damn. what a pain. races are freezing, so I ...   Sep 1 2004, 04:40 PM
Eric_Shea
  Sep 1 2004, 04:45 PM
seanery   Yeah, that confused me too. Mr. Haynes can be vagu...   Sep 1 2004, 04:47 PM
Engman   Which 914 of yours are you redoing? Yep I got som...   Sep 1 2004, 04:54 PM
lapuwali   Eric, I agree that it's good practice IF YOU H...   Sep 1 2004, 05:05 PM
seanery   Mr. Haynes agreed with Eric. But I agree with the ...   Sep 1 2004, 05:20 PM
- Lo-Fi Version Time is now: 5th July 2025 - 12:02 AM
