> Replacing Oil Cooler Seals, Engine out, this should be easy, right?
BeatNavy
post Mar 7 2015, 06:11 PM
Ok, this should be easy. I have the engine sitting on a dolly, and I'm trying to figure out where I access the oil cooler seals so I can replace them while the engine's out. I know they are on the vertical side of the cooler, and probably on the inside (not outside) side of the cooler, right? Getting access under the engine is a little difficult since it's on the dolly and I currently don't have a good view up directly underneath. What do I need to remove in order to get access to those seals? Should I attack it from the top or from underneath? I started to remove the oil filter housing but the top nut is pretty well hidden too...
r_towle
post Mar 8 2015, 04:16 PM
Custom Member
Grease gun hose or paint ball gun hose
Rich
BeatNavy   Replacing Oil Cooler Seals   Mar 7 2015, 06:11 PM
mepstein   One or 2 pieces of engine tin and the right size w...   Mar 7 2015, 06:59 PM
BeatNavy   One or 2 pieces of engine tin and the right size ...   Mar 7 2015, 07:04 PM
Dave_Darling   Just remove the fan and fan shroud. Three bolts (...   Mar 7 2015, 07:40 PM
BeatNavy   Sweet, thanks Dave. That must be the "trick....   Mar 7 2015, 07:47 PM
Larmo63   The front of the motor is like a big puzzle. It lo...   Mar 8 2015, 12:09 AM
bandjoey   http://www.pelicanparts.com/techarticles/9...ooler...   Mar 8 2015, 10:53 AM
r_towle   Yup, remove fan, fan housing, alternator. Oil cool...   Mar 8 2015, 01:44 PM
BeatNavy   Cool, thanks for the comments, gentlemen. Yup, t...   Mar 8 2015, 04:06 PM
r_towle   Grease gun hose or paint ball gun hose Rich   Mar 8 2015, 04:16 PM
BeatNavy   Grease gun hose or paint ball gun hose Rich Ok,...   Mar 8 2015, 04:26 PM
BeatNavy   Here's the engine tin after powdercoating. No...   Mar 8 2015, 04:28 PM
The Cabinetmaker   Your missing two little flat pieces of metal that ...   Mar 8 2015, 05:09 PM
BeatNavy   Your missing two little flat pieces of metal that...   Mar 8 2015, 05:14 PM
BeatNavy   Never mind. I see it on my other car. Thanks Cur...   Mar 8 2015, 05:49 PM
Stltri   Reviving an old thread. Can someone confirm the ...   Feb 14 2022, 07:35 PM
BeatNavy   Dayummm... this is an old thread. I had forgotten...   Feb 14 2022, 07:47 PM
Stltri   Dayummm... this is an old thread. I had forgotte...   Feb 14 2022, 08:06 PM
914Mels   It looks like the remote hose has straight threads...   Feb 14 2022, 11:28 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:59 AM
