Fuse Keeps Blowing- advice? |
mikedsilva |
Mar 15 2015, 05:38 AM
Member Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand |
My new to me, 1970 914/4, has some iffy electrics..
The fuse in the number 7 spot, keeps blowing as soon as I turn the key to ignition on. So, this means I dont have any indicators or wipers working.. etc. Electrics are a little mysterious to me to be honest.. I do have a multimeter.. but I am not sure how to track this problem. I'm thinking I have a short somewhere on one of those systems.. Should I start by trying to unplug each and every component that uses that circuit, then reinstall another fuse, and turn the ignition on? How would an experienced auto electrician pinpoint a problem like this? Any and all advice appreciated.. Cheers Mike. |
Spoke |
Mar 15 2015, 07:45 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The fuse in the number 7 spot, keeps blowing as soon as I turn the key to ignition on. Do you have the lights in the ON position when you turn the ignition on? If the lights are off, fuse 7 shouldn't blow when you turn the key to ON. Check the wiring at each of the lights to make sure nothing is crossed. Remove bulbs and check the sockets. |
Lo-Fi Version | Time is now: 9th June 2024 - 02:15 AM |
