> 914-6, TDC Z1
bcheney
post Mar 23 2015, 02:16 PM
Just posted this on the Bird Board...Let me know if you can help.
http://forums.pelicanparts.com/porsche-914...tml#post8543554
SLITS
post Mar 23 2015, 06:17 PM
"This Utah shit is HARSH!"
It appears the rotor is pointed at #4. At TDC (Z1), #1 & #4 are at TDC, but one is on compression stroke and the other is on the exhaust stroke.
You need to make sure which cylinder is on the compression (firing ) stroke. Either pull the valve covers and check which cylinder has both valves closed or rotate the engine a full 360 degees and see if the rotor lines up with the mark on the dizzy again.
You MUST know that you are on the compression stroke of #1 cylinder and that is why I said to use the hose from a compression tester.
bcheney
post Mar 23 2015, 06:32 PM
QUOTE(SLITS @ Mar 23 2015, 08:17 PM) *
What color point on the rotor needs to align with the mark on this dizzy Once I am sure I have it at TDC Z1? I marked the picture up Red, Blue or Yellow to make it easy to understand.
bcheney   914-6   Mar 23 2015, 02:16 PM
Al Meredith   Brian, I think the mark on the rim of the dist. sh...   Mar 23 2015, 03:03 PM
rgalla9146   Just posted this on the Bird Board...Let me know ...   Mar 23 2015, 03:45 PM
SLITS   Have a compression tester? Plug the connector hos...   Mar 23 2015, 04:12 PM
bcheney   Have a compression tester? Plug the connector ho...   Mar 23 2015, 05:53 PM
SLITS   It appears the rotor is pointed at #4. At TDC (Z1...   Mar 23 2015, 06:17 PM
bcheney   It appears the rotor is pointed at #4. At TDC (Z...   Mar 23 2015, 06:32 PM
rgalla9146   Hold on there ! Continue to rotate the cran...   Mar 23 2015, 06:46 PM
rgalla9146   Doh ! Slits done covered it while I had my...   Mar 23 2015, 06:50 PM
SLITS   The rotor needs to point to your white arrow WHEN ...   Mar 23 2015, 07:18 PM
bcheney   The rotor needs to point to your white arrow WHEN...   Mar 23 2015, 07:22 PM
fixer34   Been a while since I've done this, but if I re...   Mar 23 2015, 07:47 PM
SLITS   As stated before, the leading edge of the rotor .....   Mar 23 2015, 08:56 PM
SLITS   image of "bump rotor" attached http://w...   Mar 24 2015, 08:45 AM
bcheney   image of "bump rotor" attached [url=ht...   Mar 24 2015, 09:00 AM
bcheney   ..   Mar 24 2015, 09:04 AM
mskala   I can't remember for sure, but I think what ha...   Mar 24 2015, 10:41 AM
Dave_Darling   As I said on the Bird board, the red mark--the bra...   Mar 24 2015, 08:56 AM
SLITS   The dizzy needs to be rotated counter clockwise un...   Mar 24 2015, 01:41 PM
bcheney   The dizzy needs to be rotated counter clockwise u...   Mar 24 2015, 02:50 PM
SLITS   [quote name='SLITS' post='2164917' date='Mar 24 2...   Mar 24 2015, 03:23 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:26 PM
