| bcheney |
Mar 23 2015, 02:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Just posted this on the Bird Board...Let me know if you can help.
http://forums.pelicanparts.com/porsche-914...tml#post8543554 |
| rgalla9146 |
Mar 23 2015, 06:46 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Hold on there !
Continue to rotate the crank one full revolution in the same direction and up to TDC again. Now check the dizzy. The brass tip should point to the notch in the rim of the dist. I think you will find that it is where it will be, or very close. Now comes the next question. Is it on the compression stroke ? This can be determined in two ways. Feel for clearance at both rockers on cyl. #1 ....or... devise a way to blow into the cylinder to verify that both valves are closed and there is near zero leakage. A compression tester hose or a leak-down hose with the schrader valve removed is good for this test. If you can just blow through it's 360 out. If you find this is the case, go another revolution to TDC, lift the dizzy and drop it in so that the tip points to the notch. Easy, peasey. |
bcheney 914-6 Mar 23 2015, 02:16 PM
Al Meredith Brian, I think the mark on the rim of the dist. sh... Mar 23 2015, 03:03 PM
rgalla9146
Just posted this on the Bird Board...Let me know ... Mar 23 2015, 03:45 PM
SLITS Have a compression tester? Plug the connector hos... Mar 23 2015, 04:12 PM
bcheney
Have a compression tester? Plug the connector ho... Mar 23 2015, 05:53 PM
SLITS It appears the rotor is pointed at #4. At TDC (Z1... Mar 23 2015, 06:17 PM
bcheney
It appears the rotor is pointed at #4. At TDC (Z... Mar 23 2015, 06:32 PM
rgalla9146 Doh !
Slits done covered it while I had my... Mar 23 2015, 06:50 PM
SLITS The rotor needs to point to your white arrow WHEN ... Mar 23 2015, 07:18 PM
bcheney
The rotor needs to point to your white arrow WHEN... Mar 23 2015, 07:22 PM
fixer34 Been a while since I've done this, but if I re... Mar 23 2015, 07:47 PM
SLITS As stated before, the leading edge of the rotor ..... Mar 23 2015, 08:56 PM
SLITS image of "bump rotor" attached
http://w... Mar 24 2015, 08:45 AM
bcheney
[url=ht... Mar 24 2015, 09:00 AM
bcheney .. Mar 24 2015, 09:04 AM
mskala I can't remember for sure, but I think what ha... Mar 24 2015, 10:41 AM
Dave_Darling As I said on the Bird board, the red mark--the bra... Mar 24 2015, 08:56 AM
SLITS The dizzy needs to be rotated counter clockwise un... Mar 24 2015, 01:41 PM
bcheney
The dizzy needs to be rotated counter clockwise u... Mar 24 2015, 02:50 PM
SLITS
[quote name='SLITS' post='2164917' date='Mar 24 2... Mar 24 2015, 03:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:29 PM |
