| bcheney |
Mar 23 2015, 02:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Just posted this on the Bird Board...Let me know if you can help.
http://forums.pelicanparts.com/porsche-914...tml#post8543554 |
| SLITS |
Mar 23 2015, 08:56 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
As stated before, the leading edge of the rotor ... the copper/brass part at the end (which I didn't say) needs to be lined up with the mark in the distributor body. The contact end (copper brass) is opposite the black/grey piece of metal sticking up (This is actually a ground to short the spark when the rotor designated RPM limit is reached).
Hopefully this gets you through the process. |
bcheney 914-6 Mar 23 2015, 02:16 PM
Al Meredith Brian, I think the mark on the rim of the dist. sh... Mar 23 2015, 03:03 PM
rgalla9146
Just posted this on the Bird Board...Let me know ... Mar 23 2015, 03:45 PM
SLITS Have a compression tester? Plug the connector hos... Mar 23 2015, 04:12 PM
bcheney
Have a compression tester? Plug the connector ho... Mar 23 2015, 05:53 PM
SLITS It appears the rotor is pointed at #4. At TDC (Z1... Mar 23 2015, 06:17 PM
bcheney
It appears the rotor is pointed at #4. At TDC (Z... Mar 23 2015, 06:32 PM
rgalla9146 Hold on there !
Continue to rotate the cran... Mar 23 2015, 06:46 PM
rgalla9146 Doh !
Slits done covered it while I had my... Mar 23 2015, 06:50 PM
SLITS The rotor needs to point to your white arrow WHEN ... Mar 23 2015, 07:18 PM
bcheney
The rotor needs to point to your white arrow WHEN... Mar 23 2015, 07:22 PM
fixer34 Been a while since I've done this, but if I re... Mar 23 2015, 07:47 PM
SLITS image of "bump rotor" attached
http://w... Mar 24 2015, 08:45 AM
bcheney
[url=ht... Mar 24 2015, 09:00 AM
bcheney .. Mar 24 2015, 09:04 AM
mskala I can't remember for sure, but I think what ha... Mar 24 2015, 10:41 AM
Dave_Darling As I said on the Bird board, the red mark--the bra... Mar 24 2015, 08:56 AM
SLITS The dizzy needs to be rotated counter clockwise un... Mar 24 2015, 01:41 PM
bcheney
The dizzy needs to be rotated counter clockwise u... Mar 24 2015, 02:50 PM
SLITS
[quote name='SLITS' post='2164917' date='Mar 24 2... Mar 24 2015, 03:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:55 PM |
