| Downerman |
Mar 25 2015, 12:12 PM
Member ![]() ![]() Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None |
This is a Renegade 914 with a small block chevy. Aluminum radiator with dual fans up front that automatically engages with a temp sensor. There are two relays on the fan shroud but when the temp sensor kicks, both fans come on.
So, with that information, I also have a A/C unit that is a popular unit sold for hotrods and other custom applications. It mounts pretty nicely under the passenger side and the install was pretty straight forward. What I just learned though.... the A/C unit will never work properly while I'm filling and testing in my garage and I don't reach fan kick on temp of 195 degrees. My question is this. I need to hook my compressor power wire additionally to my fans so regardless of what temp the car is at, when the A/C is flipped on, the fans turn. on. I'm worried though because what would happen if I had the A/C on with temp below 195 and fans a blazing, then temp rises and hits 195 and gets the signal from the temp sensor to turn on? Seems like a fairly simple circuit but do you think I would need another relay from the A/C compressor power wire? I'm struggling with this and bet someone has been down this road and could maybe help me out. Thanks, Dave |
Spoke I'm assuming the temp sender is a switch mount... Mar 25 2015, 01:56 PM
Downerman
I'm assuming the temp sender is a switch moun... Mar 25 2015, 03:04 PM
Spoke
I'm assuming the temp sender is a switch mou... Mar 25 2015, 07:32 PM
somd914 I believe what you want to do is have the AC power... Mar 25 2015, 08:00 PM
Mike Bellis The easy way is to buy a dual fan controller with ... Mar 25 2015, 08:40 PM
Downerman
The easy way is to buy a dual fan controller with... Mar 26 2015, 12:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:57 AM |
