> Need some basic electrical advise
Downerman
post Mar 25 2015, 12:12 PM
This is a Renegade 914 with a small block chevy. Aluminum radiator with dual fans up front that automatically engages with a temp sensor. There are two relays on the fan shroud but when the temp sensor kicks, both fans come on.
So, with that information, I also have a A/C unit that is a popular unit sold for hotrods and other custom applications. It mounts pretty nicely under the passenger side and the install was pretty straight forward. What I just learned though.... the A/C unit will never work properly while I'm filling and testing in my garage and I don't reach fan kick on temp of 195 degrees.
My question is this. I need to hook my compressor power wire additionally to my fans so regardless of what temp the car is at, when the A/C is flipped on, the fans turn. on. I'm worried though because what would happen if I had the A/C on with temp below 195 and fans a blazing, then temp rises and hits 195 and gets the signal from the temp sensor to turn on?
Seems like a fairly simple circuit but do you think I would need another relay from the A/C compressor power wire?
I'm struggling with this and bet someone has been down this road and could maybe help me out.
Thanks,
Dave
Spoke
post Mar 25 2015, 01:56 PM
Jerry
I'm assuming the temp sender is a switch mounted on the block of the engine and closes its contact to ground when it reaches a certain temperature. This contact likely energizes the coil of a relay which turns the fan on.
Simple connection is to use a second relay where the coil is energized by the AC. The contacts of the AC relay then are connected across the temp sender (ground and sender contact).
AC turns on, fans turn on. Temp > 195, fans turn on. Everyone is happy.
Downerman
post Mar 25 2015, 03:04 PM
QUOTE(Spoke @ Mar 25 2015, 12:56 PM) *
The temp sensor is actually on the radiator but same concept. what type of relay would you suggest? I don't need to worry about voltage if one is already on?
Dave
Spoke
post Mar 25 2015, 07:32 PM
Jerry
QUOTE(Downerman @ Mar 25 2015, 05:04 PM) *
Dave
The standard relay used on the 914 will work fine. Keep in mind that the radiator switch is just that: a switch just like the contacts on the relay. By putting the AC relay contacts across the radiator switch you basically have 2 switches doing the same thing.
- Lo-Fi Version Time is now: 2nd April 2026 - 11:06 AM
