How *should* my brake pedal feel, 'cause mine feels like a spring |
72 IXXIV |
Mar 27 2015, 11:45 AM
Member Group: Members Posts: 62 Joined: 1-January 15 From: San Francisco Member No.: 18,277 Region Association: Northern California |
I had a local 914 specialist go over my car after I bought it. Among the things he did was replace all of the rubber brake lines, which were getting weepy. So the system was bled recently.
I expect unassisted brakes to require a lot of effort, and these do. But the pedal never totally firms up. Even when I'm exerting enough force to lock up a wheel, there is still travel. It feels like a spring that can keep stretching. At some point, the pedal should get hard. Maybe not rock hard, but more like squishing a rubber puck than stretching a spring. No? I also found a little brake fluid on the floor of my garage. But there does not appear to be any leaking around the cover that hides the master cylinder, steering rack, etc. Maybe its from the reservoir drain? The reservoir is full. Thanks for your thoughts! |
Porschef |
Mar 28 2015, 08:07 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Very nice photo sequence, Mark. My brake pedal has some somewhat unusual feel, it's relatively firm for most of the travel, then has a little bit of additional just when you'd think it would lock up the brakes. But it doesn't. I did just recently find that my right rear caliper is weeping fluid but I'm not sure if that's got anything to do with it since there had not been any prior fluid loss in the reservoir.
I have a pair of replacement rear calipers to install, courtesy of another member (IMG:style_emoticons/default/beerchug.gif) But between the fact that it's snowing (again) and I'm a slacker, I haven't installed them yet. At this rate, I'd be surprised if all the salt was off the road by the time Hershey rolls around... (IMG:style_emoticons/default/bs.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 10:21 AM |
