Cracker Jack Prize, engine disassembly |
r3dplanet |
Mar 29 2015, 08:56 PM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
Hello peeps.
I'm back from a long period of hibernation following my bone marrow transplant. Here's a helpful life hacking skill: do not get cancer. During the eight months I was gone, my birthday came and went. Now I'm 42. Things are much different now that I'm back on my aching feet. For example, I now spend my days playing a new mental game called "Post Transplant or Middle Age?" to explain things like my increased waistline diameter, aching muscles, slow wit, and any other number of minor grievances. Today was the first day I've done anything 914-ish in a long, long time. Since my Corvair engine project is on hold indefinitely, I've put plans into place to convert my existing 1.7 liter engine into a 1911. Before the Corvair project I had previously bought pistons, 94mm cylinders that are good enough to bore, rockers, lifters, new cam, swivel adjusters, etc. So I decided to put them to good use and rebuild my engine. Today was a lovely Spring day complete with sunny skies and cherry blossoms. So I disassembled the engine that has been languishing in the garage since last June. Guess what? My 1.7 liter engine already has 96mm pistons and cylinders. I have no idea what the crankshaft is so maybe it's a 1911 or maybe it's a 2056. I don't know. But it certainly was a surprise since the person I bought it from was convinced it was a 1.7 liter from a 1973 car. Is there some easy way to find which crankshaft I have or do I have to wait until I split the case? What I do know is that I spent two years trying in vain to get the 1.7 liter D-Jet system to work on that engine. With today's interesting discovery I know at least that I had (and rebuilt) the wrong MPS along with the wrong injectors (VW Black for 1600-1700cc) and wrong computer. Hoo-ray! Thank you so very much 20/20 hindsight! At least I know why it ran super lean all the time. I actually feel much better about the D-Jet failure now. Chances are that it all worked perfectly well after the work I put into it. It was just the wrong engine. I blame and applaud myself simultaneously. My sincere hope is that becoming concurrently post-transplant and middle aged brings newfound wisdom along with all of the extra groaning sounds I now make. How do I identify which crankshaft I have? Cam? Your pal, Marcus |
r_towle |
Mar 30 2015, 12:15 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hello peeps. I'm back from a long period of hibernation following my bone marrow transplant. Here's a helpful life hacking skill: do not get cancer. During the eight months I was gone, my birthday came and went. Now I'm 42. Things are much different now that I'm back on my aching feet. For example, I now spend my days playing a new mental game called "Post Transplant or Middle Age?" to explain things like my increased waistline diameter, aching muscles, slow wit, and any other number of minor grievances. Today was the first day I've done anything 914-ish in a long, long time. Since my Corvair engine project is on hold indefinitely, I've put plans into place to convert my existing 1.7 liter engine into a 1911. Before the Corvair project I had previously bought pistons, 94mm cylinders that are good enough to bore, rockers, lifters, new cam, swivel adjusters, etc. So I decided to put them to good use and rebuild my engine. Today was a lovely Spring day complete with sunny skies and cherry blossoms. So I disassembled the engine that has been languishing in the garage since last June. Guess what? My 1.7 liter engine already has 96mm pistons and cylinders. I have no idea what the crankshaft is so maybe it's a 1911 or maybe it's a 2056. I don't know. But it certainly was a surprise since the person I bought it from was convinced it was a 1.7 liter from a 1973 car. Is there some easy way to find which crankshaft I have or do I have to wait until I split the case? What I do know is that I spent two years trying in vain to get the 1.7 liter D-Jet system to work on that engine. With today's interesting discovery I know at least that I had (and rebuilt) the wrong MPS along with the wrong injectors (VW Black for 1600-1700cc) and wrong computer. Hoo-ray! Thank you so very much 20/20 hindsight! At least I know why it ran super lean all the time. I actually feel much better about the D-Jet failure now. Chances are that it all worked perfectly well after the work I put into it. It was just the wrong engine. I blame and applaud myself simultaneously. My sincere hope is that becoming concurrently post-transplant and middle aged brings newfound wisdom along with all of the extra groaning sounds I now make. How do I identify which crankshaft I have? Cam? Your pal, Marcus Welcome back. Not the same as you, certainly not as drastic, but after a year of abdominal surguries, multiple issues, I found that the only way to avoid the groans is the get to a gym and become in better shape than ever before... For the motor. If you pull the cylinders, check the pin height on the piston compared to the pin height on 1.7/1.8 pistons and 2.0 liter pistons. That will tell you the stroke. If you have not pulled the cylinders, measure the stroke as you rotate the engine from TDC to BDC on any cylinder. Camshaft can be measured by coming in via a lifter hole (remove push rod and tube) and setup a dial indicator that rides the lifter. You would need a degree wheel setup properly, then document when it starts the lift, and the lift height, and duration. Should be one of these (close enough) measurements to let you know if it is a stock camshaft or not. From there, if its not stock, I would open it up and do a better job of measuring,but I think its easier to measure an unknown camshaft with it installed in the case and using a degree wheel....and I would prefer to measure off the lifter to eliminate all the math.... |
Lo-Fi Version | Time is now: 1st June 2024 - 01:41 PM |
