| 03blueboo |
Apr 6 2015, 12:58 PM
Newbie ![]() Group: Members Posts: 31 Joined: 9-July 13 From: Lexington, KY Member No.: 16,108 Region Association: South East States |
Has anyone replaced door handles recently? With out going into too much background, I changed both the exterior and interior handles. Now, with the door panel on, I can't get the door open from the inside. Is there an adjustment somewhere in the door that will take a little slack out of the rod connecting the handle to the unlocking mechanism?
| Mike Bellis |
Apr 6 2015, 06:51 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Make sure you use the short screw on the handle and not the one from the window crank. The longer screw can stop the handle from working.
| SirAndy |
Apr 6 2015, 06:56 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,538 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
03blueboo Door handle adjustment Apr 6 2015, 12:58 PM
stugray What happens if you pull back on JUST the lock tab... Apr 6 2015, 01:28 PM
era vulgaris I had a similar situation with my old '72. Wh... Apr 6 2015, 03:23 PM
03blueboo Thanks all. Yes, I tried pulling on just the lock... Apr 6 2015, 10:53 PM
The Cabinetmaker It's the screw! Apr 7 2015, 01:11 AM
rmdinmd on mine the metal failed and I had to replace it (... Apr 7 2015, 06:24 AM
boxstr Shorten your screw and reinsert :miles:
Craig at ... Apr 7 2015, 08:09 AM
03blueboo I didn't get a chance to mess with it last nig... Apr 7 2015, 12:55 PM
Dave_Darling You swapped the screws between the window crank an... Apr 7 2015, 01:35 PM
03blueboo It was the screw. I want to say that most of the ... Apr 8 2015, 08:10 PM
stugray Glad to hear it was easy!
I wish it was that ... Apr 8 2015, 08:15 PM
Deusexmachina77 I can't believe this worked.
The simplest fix ... Aug 26 2023, 12:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th October 2026 - 12:29 AM |
