First start after rebuild, No oil pressure... Someone help me..please! |
DavidSweden |
Apr 18 2015, 04:33 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Engine 2.0 76
Rebuilt engine and should start it today. Pulled the plugs and filled oil. Cranked engine to get oil pressure but nothing. Pulled pressure switch and tested with compressed air works fine. Loosened oil filter and cranked again oil ran from filter, tightened filter and tried again.... Nothing. Oil type 20W 50 Need some advice on what to check to find source or problem.... It's just a Pita |
McMark |
Apr 18 2015, 02:08 PM
It's a possibility. If you pull the big piston back out and use a length of rod in place of the spring, you can keep the oil from bypassing. The motor shouldn't run the way though. (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 01:49 PM |
