First start after rebuild, No oil pressure... Someone help me..please! |
DavidSweden |
Apr 18 2015, 04:33 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Engine 2.0 76
Rebuilt engine and should start it today. Pulled the plugs and filled oil. Cranked engine to get oil pressure but nothing. Pulled pressure switch and tested with compressed air works fine. Loosened oil filter and cranked again oil ran from filter, tightened filter and tried again.... Nothing. Oil type 20W 50 Need some advice on what to check to find source or problem.... It's just a Pita |
Highland |
Apr 18 2015, 04:56 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Just my 2 cents, but I couldn't build oil pressure with just the starter turning the motor. When I removed the oil pressure gage oil was in the boss so I figured oil was in the system since I did no priming.
Started the motor and oil pressure came to specified range immediately. I've started the motor twice and ran the cam break in procedure, but have yet to install, so the verdict is still out on my engine:) |
DavidSweden |
Apr 19 2015, 01:34 AM
Just my 2 cents, but I couldn't build oil pressure with just the starter turning the motor. When I removed the oil pressure gage oil was in the boss so I figured oil was in the system since I did no priming. Started the motor and oil pressure came to specified range immediately. I've started the motor twice and ran the cam break in procedure, but have yet to install, so the verdict is still out on my engine:) Thanks Highlander, If there are no more ideas from members as what to do then I will probably go that route. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:58 PM |
