Transaxle issue?, Feels like I'm running over speed bumps |
rtalich |
Apr 17 2015, 10:18 AM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
Issue just started last night. Just starting out in first gear while slipping the clutch. Once clutch engages at lower RPMs it felt like I was rolling over speed bumps. At faster speeds it seemed fine. Now it is starting to happen more frequent but only at lower RPMs. I have not had a chance to diagnose yet. Anything in particular come to mind?
Thanks Rob |
rtalich |
Apr 19 2015, 11:47 AM
I think I may have found the problem. The ball joint was still attached. I pulled it slightly and it popped out. Anyone know where I can get parts?
Attached thumbnail(s) |
messix |
Apr 19 2015, 12:42 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
I think I may have found the problem. The ball joint was still attached. I pulled it slightly and it popped out. Anyone know where I can get parts? not likely the problem there are the two little engine to engine bar mounts that can tear apart and you feel a bump when pulling away for a stop and can see the shift leaver move as it happens. or as said before, loose wheel |
rtalich |
Apr 19 2015, 01:05 PM
I think I may have found the problem. The ball joint was still attached. I pulled it slightly and it popped out. Anyone know where I can get parts? not likely the problem there are the two little engine to engine bar mounts that can tear apart and you feel a bump when pulling away for a stop and can see the shift leaver move as it happens. or as said before, loose wheel Thanks! I will do a bit more investigating. Would you happen to to have a pic of what you are referring to? |
Lo-Fi Version | Time is now: 16th June 2024 - 10:42 AM |
