Heater blower, Maintenance |
jsaum |
Apr 23 2015, 02:23 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
My heater blower in the engine compartment had a bad bearing I was able to switch it out with a spare motor it was a real pia. My question is how often should you take the electric motor apart and clean and oil the bearings?
Bartlett 914 |
Apr 23 2015, 02:55 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
My heater blower in the engine compartment had a bad bearing I was able to switch it out with a spare motor it was a real pia. My question is how often should you take the electric motor apart and clean and oil the bearings? I wouldn't remove it unless there was an issue. If you are installing one, I would bench test it first. |
Lo-Fi Version | Time is now: 9th June 2024 - 02:02 AM |
