Heater blower, Maintenance |
jsaum |
Apr 23 2015, 02:23 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
My heater blower in the engine compartment had a bad bearing I was able to switch it out with a spare motor it was a real pia. My question is how often should you take the electric motor apart and clean and oil the bearings?
Bartlett 914 |
Apr 23 2015, 02:55 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
My heater blower in the engine compartment had a bad bearing I was able to switch it out with a spare motor it was a real pia. My question is how often should you take the electric motor apart and clean and oil the bearings? I wouldn't remove it unless there was an issue. If you are installing one, I would bench test it first. |
Spoke |
Apr 23 2015, 06:00 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I wouldn't remove it unless there was an issue. If you are installing one, I would bench test it first. (IMG:style_emoticons/default/agree.gif) Squeaky wheel gets the grease. Had this happen to 2 Audi's, a 1995 and 1997; heater fan squeaked at low speed. Removed the fan and motor, oiled and replaced. Big PITA on those cars. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:37 PM |
