Wanted 914-6 Wiper Assembly & Motor |
racerbvd |
Apr 25 2015, 11:24 AM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Turns out that my wiper motor & parts vanished, so, now I need a replacement, any help would be appreciated.
914-628-019-10-OEM is the part number for the motor, it the rest the same as a 4?? Either way, looks like I need a replacement (IMG:style_emoticons/default/mad.gif) TIA |
914Sixer |
Apr 25 2015, 10:12 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Yes, you can take a tubing cutter and shorten the 911 rack and install the -4 wiper arm assembly. Remove the strap and drill a hole for the post mount. You then have a -6 rack.
911 wiper motor will need a harness made up to plug into column harness. |
sixnotfour |
Apr 26 2015, 09:49 AM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Yes, you can take a tubing cutter and shorten the 911 rack and install the -4 wiper arm assembly. Remove the strap and drill a hole for the post mount. You then have a -6 rack. 911 wiper motor will need a harness made up to plug into column harness. (IMG:style_emoticons/default/agree.gif) with pics here; http://www.914world.com/bbs2/index.php?showtopic=254282 |
Lo-Fi Version | Time is now: 1st June 2024 - 06:21 AM |
