| pgollender |
Apr 26 2015, 11:28 PM
Member ![]() ![]() Group: Members Posts: 201 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
I decided to replace the ball socket on my 1970 shifter . I didn't realize the plate springs were under so much tension. I haven't found a way to put them back.
Any body have an idea ? ![]() |
| Old Yella |
Apr 26 2015, 11:54 PM
Old Yella ![]() ![]() Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
I decided to replace the ball socket on my 1970 shifter . I didn't realize the plate springs were under so much tension. I haven't found a way to put them back. Any body have an idea ? ![]() Yep they are a bitch. I bent a small hook on the end of stiff piece of wire. Placed the wire through one of the holes on the side of the shifter base. Placed the spring on the wire. Pulled the wire to compress the spring and get it in between the two holes in the shifter. passed a Phillips screw driver through the holes and spring whilst simultaneously cutting the hook off the wire with wire cutters. Then followed through with the retaining pin pushing the screwdriver out. Same again for the other one. You need strong fingers. It was a bitch but I have done it a few times that way now. Don't know if there is a special tool. |
pgollender Shifter springs re-install Apr 26 2015, 11:28 PM
mepstein Leather gloves. Safety glasses vise grips. I used ... Apr 27 2015, 04:09 AM
jim_hoyland There is an easy way, i recently did it. Forget ex... Apr 27 2015, 04:49 AM
saigon71 Oh yeah...good times with those springs!
I pu... Apr 27 2015, 05:55 AM
maf914 It can be done, but what a pain! I launched t... Apr 27 2015, 07:03 AM
rhodyguy Put one end of a spring near a hole. Push one of t... Apr 27 2015, 07:22 AM
bdstone914 Cap'n Krusty replied to a thread explaining to... Apr 27 2015, 07:22 AM
Brian_Boss First off, if you are not holding the housing in a... Apr 27 2015, 09:55 AM
r_towle
First off, if you are not holding the housing in ... Apr 30 2015, 03:02 PM
pgollender Thanks everyone:
With the advice given, I found it... Apr 28 2015, 03:18 PM
rhodyguy Well presented. The lever ball bushing are often o... Apr 28 2015, 11:39 PM
pgollender
....The contact edge of the detention plate is pr... Apr 29 2015, 11:40 PM
rhodyguy this is a pretty clean detent plate. junked up spr... Apr 29 2015, 11:51 AM
rhodyguy Yes, pelican. I had missed the picture showing the... Apr 30 2015, 06:30 AM
maf914 Some what off topic, but, Weltmeister offered a ki... Apr 30 2015, 08:04 AM
rhodyguy Over kill. I bought into the hype and promptly too... Apr 30 2015, 08:21 AM
malcolm2 Glad you did this. And has been the case with my ... Apr 30 2015, 09:51 AM
rhodyguy iirc with the spring kit as per instructions you d... Apr 30 2015, 10:19 AM
johnhora nice write up pgollender...
I made this tool a lo... Apr 30 2015, 02:51 PM
malcolm2
I made this tool a l... Apr 30 2015, 03:54 PM
malcolm2
Waiting on the tranny to return so i took my si... Apr 30 2015, 04:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th October 2026 - 07:16 PM |
