PDK Transmission, who else does this |
r_towle |
Apr 27 2015, 02:58 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
From what I have learned, little at most....
PDK is a dual clutch transmission that basically shifts ahead of you and is waiting for a click of the paddle to flip from one clutch to the other....the secondary clutch is already engaged and ready to go on any given gear....but its thinking ahead, certainly based on software and accel or decel mode.. So, who else is doing a dual clutch like this? Yes, this is a bit ADD (Scotty) but I am thinking ahead for when a clutch may no longer be a simple part of my daily routine. Does subaru do this, or audi (something I can transplant) or any other car that would not cost me an arm and a leg to transplant? And yes, I may want to flip the tranny, or possibly run it backwards....so mid or rear engine... Rich |
Mike Bellis |
Apr 27 2015, 09:10 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
If you want a performance automatic, you can't be cheap. The VW Passat triptronic would be the cheapest way. For about $500 you can find them. You also need the TCM and wire harness. Then you need to figure out machine work to get a starter near the 914 position. You would also need to figure out a way to trick the TCM into working correctly.
The Passat trannies are basically Boxster trannies for a fraction of the price. The best way to do this is to buy a 1997 Boxster and use the engine and tranny. Whoops, water cooled. Early Boxsters with automatics can be had for under $7k |
Lo-Fi Version | Time is now: 16th June 2024 - 01:36 PM |
