Sudden stalls |
Sudden stalls |
BfloRandy |
Apr 15 2015, 12:27 PM
Dimwit Extraordinaire Group: Members Posts: 66 Joined: 20-September 14 From: Buffalo, NY Member No.: 17,927 Region Association: North East States |
Good day, everyone. Having an issue that began in December, right before I covered the car for the winter. I have a '75 2.0 dual carbed (Weber 40). The car starts as it always has, that is, takes a try or two when it's warm out, and she's ready. Regardless of whether she's warmed up or still relatively cold, sometimes she just cuts out. This can happen at idle, or 3500 rpm. Doesn't seem to matter. When this happens, sometimes she starts right back up just by turning the key, other times, she needs a pump or two on the pedal, and yet other times, she just won't restart for what seems like forever. This is not an issue all the time. It may happen daily for a week, then not again for another week. I was just outside adjusting the carbs, and she died on me a half dozen times but restarted with just the key turned. The last time of course, she wouldn't restart. Probably will now that I've come inside... I don't know if this is a timing issue, a distributor issue, a fuel pump (and/or pump relay) issue. As you can tell, I'm a noob. Help?? More (helpful or not?) info: I went back out to give it another shot, same result. She didn't want to start. Cranks very well, brand new battery... On a whim, I popped the cap off of the distributor, everything inside looked fine. checked all the wires, they're pretty new and plugged in solidly. Got back in, and she fired right up, then died again almost immediately. Back to not wanting to start. Tried fiddling with the cap again, no help this time. I know I have a spare fuel filter lying around somewhere, gonna swap that in just for kicks. FWIW, when she is running, she goes just fine.
BfloRandy |
Apr 29 2015, 03:28 PM
Ok, ladies and gents! Back to work on my frustration! The fuel pump is now wired with a dedicated, switched line. It clicks like crazy when it should. The coil has been replaced, and gets good spark from terminal 4 to the fan housing. I started (yes, started!) her up, first shot, and easily. After about a minute she began to stumble, and quit, as if running out of gas. Now she won't start again. I unhooked the exit line from the fuel filter, and checked supply. Upon turning the key, I get an initial spurt of gas, then no more. What the? Did I crimp the hose?
Yep... She is running nicely now, thank all of you for your help! |
Lo-Fi Version | Time is now: 9th June 2024 - 11:06 PM |
