tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
Argh- I rebuilt a 2.7l this winter. Everything went very well with no obvious problems. I installed my engine, hooked up all the hoses, filled with oil and hooked up the starter. I had problems with the starter wiring however I finally got them resolved. I was getting 12.6v at the starter. I cranked the starter and the engine turned a couple of times then stopped. When I would crank the starter again, it would just sound like a starter with too low of voltage- the solenoid would shoot out but the starter wouldn't turn. I checked voltage and it was 12.5v. If I look at the fan blade when I crank the starter, I do not see it move even slightly.
What are my options of what could be wrong? I see it as a starter problem or the engine is somehow seized. I do not have the axels hooked up so I cannot see if the engine turns by pushing the car in gear. I have a small window cut in the firewall so I wiggled a 19mm box wrench onto the timing pulley nut. I tried to see if I could turn the engine even slightly and I could not. I couldn't put much force into it however I would have thought it would have moved to some extent. I think I will remove the starter and see if it cranks off of the car. If it functions properly, how can I check to see if the engine is seized without installing the axles. Is there anything common that could cause this issue? I would really prefer not to remove the engine. I am getting somewhat sick of working on it. Any ideas? |
tornik550 |
I went out and removed the transmission only from eh car. The transmission turned without difficulty. I tried to turn the engine and it still would not turn so I removed the pressure plate and clutch. Still the engine wouldn't turn. I decided to remove the flywheel. I figured a flywheel lock wasn't needed since the engine wouldn't turn. I put some muscle into removing the flywheel bolts. Before the first one started to turn, it felt like something broke free and now the engine turns like it previously did.
Now what? Was it bound to something that broke free? Something related to the flywheel that I can't see? Did something break (didn't sound like it)? Where should I go from here? |
Lo-Fi Version | Time is now: 15th June 2024 - 10:49 PM |
