Oil analysis on a 911 race engine, elevated lead/copper? |
stownsen914 |
May 3 2015, 10:58 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Hi all,
I posted this question on the Pelican board, and would like to get opinions here as well. I'd like to get your input on the oil analysis I just had done on a 911 race engine from my 914/6. It shows elevated lead and copper, which I'm guessing could mean bearing wear. Does this mean the engine is just moving toward rebuild time, or does it mean "don't drive it anymore, rebuild now"? A few details: - I do use leaded gas, which I understand can explain the high lead level in the oil - The engine is a short stroke 2.7 (93 x 66), is revved to 7500 with no overrevs, and has about 55 track hours on it. The summary mentions "cautionary" about the lead but doesn't use as strong language about the copper. It also says that lead seems may be explainable from the leaded gas. I was expecting a little more time before a rebuild, but maybe time's up? In addition to the oil analysis report, I'm also including some pics of the Canton oil filter element that I run in place of the stock oil cooler on the engine. I have not changed or inspected this filter in a long time, as I use an coarser screen element nspection filter in the scavenge side of the oil system (definitely a mistake to not have checked the filter on the engine more often). Note a significant amount of metal bits, with some of them being magnetic (last blurry pic shows a magnet I trolled around on the filter element). Could this be acceptable given the extended period of time this filter was in service? Thanks in advance for your opinions! Scott Attached image(s) |
Matt Romanowski |
May 5 2015, 11:07 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Having done lots of oil changes with metal in the filter like that, I would say take it apart sooner than later. Will one more event hurt it - probably not, but you've got something going on in the motor.
Also, my personal opinion is to only use the Canton filters for float tests and run a regular, quality filter like a Wix, Mehle, Mann, etc. Then cut it open every couple of events to see what is in there. You should not find much if anything in the pleats of a filter. |
stownsen914 |
May 5 2015, 01:46 PM
Thanks Matt. I'm planning a club race later this week, and I think that'll be the last event on this motor.
Re: the Canton filter, I'm using the tall, canister style ones, one with a coarse screen and a second with an 8 micron disposable element. Are you thinking this is too coarse, or not up to the task in some other way? I'm planning to do filter inspections after each of the first few runs to make sure no significant new materials is being shed. Otherwise I just park it. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:16 AM |
