Issues with Beetle CV joint failure? |
stownsen914 |
Apr 22 2015, 09:10 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Hi all,
With 914 CV joints being NLA now, I recently tried out Beetle CV joints when my old ones wore out on my 914/6 race car. I understand they are made by EMPI. I am using the same 914 axles I've used for years. After about 30 minutes of track time, one of the Beetle joints failed (the inner one on the right side of the car). Basically the joint seems to have been plunging too far inward and the lateral force seems to have just forced the joint apart. No broken parts are immediately apparent. The joint seems to have just fallen apart! I also noted that the inner races of the joints seem to be gouging the output flanges on the trans. This occurred on both sides fo the car. I had noticed some of this wear previously, but it seems to have accelerated significantly with the Beetle joints (especially considering only 30 minutes of use). See the pics below. It's hard to tell from the pics, but the wear spots are basically gouged into the flanges about a millimeter or so deep. I never had any failures or unusual wear with the 914 joints I used for years, so I am at a loss what happened here. Anyone have a similar issue with Beetle joints? I'm wondering if I should be trying Lobro or other joints, or a different setup entirely ... Attached image(s) |
mskala |
May 7 2015, 07:01 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Unless I'm wrong about how CV's work, the amount of extension is related to
the length of the slots in the cage (all else being the same). The EMPI Type 1 units I just got from Chris have a slot length of about 960mil. The Meyle Type 1 units I removed had a slot length of about 900mil. I'm not an expert here, just an FYI. |
ChrisFoley |
May 7 2015, 08:12 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Unless I'm wrong about how CV's work, the amount of extension is related to the length of the slots in the cage (all else being the same). Actually, my observations have not supported that. The balls never reach the end of the slots in OE 914 CVs. It may be that the angle of the grooves is different. |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:05 AM |
