> Type 4 megasquirt
r_towle
post Apr 30 2015, 06:43 PM
Custom Member
I am looking for a roll call with details on any type 4 EFI people.
hope we can keep this thread on track.
Please tell us
What size motor
What EFI brain are you using
What throttle body setup do you have
What size injectors are you using
ignition?
And any data logging?
FourBlades
post May 11 2015, 05:03 PM
From Wreck to Rockin
Some pictures of my EFI setup. Mine uses electromotive for the ECU but most of the
stuff is the same as you would use for megasquirt. I think the electromotive uses a
different number of teeth on its trigger wheel.
Here is what the CB Performance throttle bodies look like with their fuel rails,
injectors, and the metal tab that holds the fuel rails to the throttle body.
The tube coming out from the between the manifolds is an air line that goes to the
manifold pressure sensor in the rear trunk. The throttle bodies are drilled and
tapped for this air line and the lines from both throttle bodies join together before
going to the manifold pressure sensor. These long air lines help smooth the air
pressure pulses at low RPM but they still fluctuate a lot below something like 2500
RPM. Below 2500 RPM (or so) the electromotive relies on the throttle position
sensor mounted to the back of one throttle body for its load input. It can blend
between the two to smooth things out at low RPM. Not sure what megasquirt does
here but I bet it is something similar.
Here is a close up of the metal tab holding the fuel rail to the throttle body. I had a
hard time getting pictures of this stuff with the engine installed. (IMG:style_emoticons/default/smile.gif)
Another shot of the tab.
A shot of the master side of the tangerine throttle pulley system. Edit: I had this
backwards I realized: At the top of the wheel is the throttle cable attached to the
gas pedal. At the bottom is the cable to the slave wheel on the other throttle body.
Hope this helps.
John
r_towle   Type 4 megasquirt   Apr 30 2015, 06:43 PM
Michelj13   What size motor....2270 What EFI brain are you usi...   Apr 30 2015, 11:48 PM
edwin   1800 (low comp bus pistons) Haltech sprint 500 ecu...   May 1 2015, 08:20 AM
toon1   1.7 MS1/Ms&s extra code Stock throttle body 36...   May 1 2015, 08:35 AM
aircooledtechguy   The injection I'm currently running on my 2056...   May 1 2015, 10:39 AM
r_towle   The injection I'm currently running on my 205...   May 1 2015, 03:48 PM
aircooledtechguy   [quote name='aircooledtechguy' post='2181330' dat...   May 2 2015, 01:24 PM
jd74914   And finally....did you build the ECU or do you bu...   May 3 2015, 06:15 PM
crash914   2.7liter, MSII ver 2.2, twin throttle bodies, 40 o...   May 1 2015, 03:21 PM
r_towle   2.7liter, MSII ver 2.2, twin throttle bodies, 40 ...   May 1 2015, 03:49 PM
stugray   Two brothers run megasquirts in our vintage group....   May 1 2015, 03:34 PM
crash914   Rich, download shadowtuner. It will log full mega...   May 1 2015, 04:53 PM
r_towle   Rich, download shadowtuner. It will log full meg...   May 1 2015, 07:09 PM
Michelj13   I want to get this device soon, I need to spend ...   May 2 2015, 11:24 PM
falcor75   Stock 2.0 (will be 2270 or 2316 later) Bosch 350cc...   May 3 2015, 02:09 PM
JamesM   Do you want to know what I run currently or the va...   May 3 2015, 11:01 PM
crash914   The msII ver 3.0 and 3.57 boards are nice as they ...   May 4 2015, 02:59 AM
Vacca Rabite   Rich, I have a MS 3.57 board and harness stub and...   May 4 2015, 07:56 AM
FourBlades   Some pictures of my EFI setup. Mine uses electrom...   May 11 2015, 05:03 PM
Racer Chris   A shot of the master side of the tangerine throt...   May 12 2015, 01:53 PM
r_towle   Thanx that helps alot   May 11 2015, 06:38 PM
McMark   1.7 Turbo MicroSquirt v3 Stock intake system Soon ...   May 12 2015, 01:03 PM
FourBlades   Ok, Chris, I see what you are saying. I think at ...   May 12 2015, 06:38 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:22 PM
