| arsprod |
May 17 2015, 04:26 PM
Member ![]() ![]() Group: Members Posts: 211 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
The temp gauge above my fuel gauge isn't working. For the life of me I cannot find any mention of it in the Haynes manual I have or even in the owners manual. Where's the sending unit for this thing? 74 2.0
| type47 |
May 17 2015, 05:28 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Where's the sending unit for this thing? Located in the engine sump. Also called the "taco plate" so if you need to buy the temp sender, that's what you can search for and ask for. Same temp sender would be for the console temp gauge. Your combo gauge with oil temp was installed by the factory to those cars not equipped with the center console. Here's a pic of the taco plate: ![]() ![]() Maybe you just need to verify the wire from the sender to the harness connector just below the battery tray. |
arsprod temp gauge May 17 2015, 04:26 PM
arsprod Thank you! I was looking at that yesterday tho... May 17 2015, 05:33 PM
914Sixer Wire is green with red stripe. Heat and time have... May 17 2015, 07:30 PM
arsprod
Wire is green with red stripe. Heat and time hav... May 23 2015, 11:28 AM
type47
Could it be green/black on 74?
http://www.peli... May 23 2015, 03:48 PM
arsprod
http://www.pel... May 23 2015, 06:13 PM
SKL1 Get a new sending unit for the taco plate and put ... May 23 2015, 09:25 PM
steuspeed
... I sent my gauge to North Hollywood Speedomet... May 24 2015, 01:08 AM
arsprod
Get a new sending unit for the taco plate and put... May 24 2015, 06:57 AM
arkitect
Get a new sending unit for the taco plate and put... May 24 2015, 08:24 AM
arsprod This the correct part? http://www.egauges.com/Prod... May 24 2015, 07:44 AM
Java2570
This the correct part? http://www.egauges.com/Pro... May 24 2015, 08:43 AM
bdstone914
[quote name='arsprod' post='2190641' date='May 24... May 24 2015, 12:08 PM
brant I am facing the same problem
is there anyway to te... May 24 2015, 10:07 AM
bdstone914 Measure the resistance from the center terminal to... May 24 2015, 12:03 PM
Java2570 This thread has a ton of good oil temp info: http:... May 24 2015, 02:56 PM
arsprod Hmm... maybe just replacing wire is the answer May 24 2015, 05:55 PM
SKL1 Here's a picture of the gauge panel before I p... May 24 2015, 06:36 PM
arsprod So I've confirmed a connection from sender to ... May 31 2015, 07:56 AM
forrestkhaag I recently went thru this issue with my newly rewo... May 31 2015, 08:54 AM
arsprod
I recently went thru this issue with my newly rew... May 31 2015, 09:00 AM
arsprod Back at this - I've ordered a sender finally b... Jun 14 2015, 03:21 PM
stugray + to +12VDC (dash power)
GND to chassis ground
Th... Jun 14 2015, 04:00 PM
arsprod
T... Jun 14 2015, 05:40 PM
stugray
Thank you - appears mine is missing a lead to gr... Jun 14 2015, 06:57 PM
arsprod
Thank you - appears mine is missing a lead to g... Jun 15 2015, 08:17 AM
arsprod Follow up with some potentially helpful info for f... Jun 22 2015, 10:15 AM
stugray
- the wire from the sender to my gauge was disco... Jun 22 2015, 12:48 PM
arsprod
- the wire from the sender to my gauge was disc... Jun 22 2015, 01:15 PM
stugray
Thanks, me too! Just noticed your signature -... Jun 22 2015, 04:04 PM
arsprod
Thanks, me too! Just noticed your signature ... Jun 22 2015, 05:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 06:02 PM |
