| arsprod |
May 17 2015, 04:26 PM
Member ![]() ![]() Group: Members Posts: 211 Joined: 14-March 15 From: Indianapolis Member No.: 18,519 Region Association: Upper MidWest |
The temp gauge above my fuel gauge isn't working. For the life of me I cannot find any mention of it in the Haynes manual I have or even in the owners manual. Where's the sending unit for this thing? 74 2.0
| arsprod |
May 17 2015, 05:33 PM
Thank you! I was looking at that yesterday though mine's not nearly so clean.
arsprod temp gauge May 17 2015, 04:26 PM
type47
L... May 17 2015, 05:28 PM
914Sixer Wire is green with red stripe. Heat and time have... May 17 2015, 07:30 PM
arsprod
Wire is green with red stripe. Heat and time hav... May 23 2015, 11:28 AM
type47
Could it be green/black on 74?
http://www.peli... May 23 2015, 03:48 PM
arsprod
http://www.pel... May 23 2015, 06:13 PM
SKL1 Get a new sending unit for the taco plate and put ... May 23 2015, 09:25 PM
steuspeed
... I sent my gauge to North Hollywood Speedomet... May 24 2015, 01:08 AM
arsprod
Get a new sending unit for the taco plate and put... May 24 2015, 06:57 AM
arkitect
Get a new sending unit for the taco plate and put... May 24 2015, 08:24 AM
arsprod This the correct part? http://www.egauges.com/Prod... May 24 2015, 07:44 AM
Java2570
This the correct part? http://www.egauges.com/Pro... May 24 2015, 08:43 AM
bdstone914
[quote name='arsprod' post='2190641' date='May 24... May 24 2015, 12:08 PM
brant I am facing the same problem
is there anyway to te... May 24 2015, 10:07 AM
bdstone914 Measure the resistance from the center terminal to... May 24 2015, 12:03 PM
Java2570 This thread has a ton of good oil temp info: http:... May 24 2015, 02:56 PM
arsprod Hmm... maybe just replacing wire is the answer May 24 2015, 05:55 PM
SKL1 Here's a picture of the gauge panel before I p... May 24 2015, 06:36 PM
arsprod So I've confirmed a connection from sender to ... May 31 2015, 07:56 AM
forrestkhaag I recently went thru this issue with my newly rewo... May 31 2015, 08:54 AM
arsprod
I recently went thru this issue with my newly rew... May 31 2015, 09:00 AM
arsprod Back at this - I've ordered a sender finally b... Jun 14 2015, 03:21 PM
stugray + to +12VDC (dash power)
GND to chassis ground
Th... Jun 14 2015, 04:00 PM
arsprod
T... Jun 14 2015, 05:40 PM
stugray
Thank you - appears mine is missing a lead to gr... Jun 14 2015, 06:57 PM
arsprod
Thank you - appears mine is missing a lead to g... Jun 15 2015, 08:17 AM
arsprod Follow up with some potentially helpful info for f... Jun 22 2015, 10:15 AM
stugray
- the wire from the sender to my gauge was disco... Jun 22 2015, 12:48 PM
arsprod
- the wire from the sender to my gauge was disc... Jun 22 2015, 01:15 PM
stugray
Thanks, me too! Just noticed your signature -... Jun 22 2015, 04:04 PM
arsprod
Thanks, me too! Just noticed your signature ... Jun 22 2015, 05:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 06:04 PM |
